Music & Car Audio Chat Most of your cars have a great sound system and you love music yeah? Discuss these things here...
sub problem?
Old Sep 14, 2009 | 08:48 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default sub problem?
right all of a sudden my sub has stopped working but only on cd mode on head unit? it all works fine with the radio on but as soon as you change to play cd's it just will not work.
anybody got any ideas or does it soundlike the head unit is fooked
Old Sep 14, 2009 | 11:57 PM
bassboy's Avatar
bassboy
more than likely a headunit problem...a quick test though, is the amp light still staying on when the cd is playing?
bassboy
Old Sep 20, 2009 | 02:54 PM
Dicko&Vacant
bassboy
amp light is going out when CD is on, but light is back on when the radio is back on
Old Sep 20, 2009 | 07:52 PM
bassboy's Avatar
bassboy
definately headunit related, try this;
disconnect your remote cable, get another wire and bridge it over from the positive lead so the amp is on constant, if everything works fine, its 101% headunit
bassboy
Old Sep 20, 2009 | 08:53 PM
Dicko&Vacant
ok mate will try that, thanks very much, will let you know what happens
Old Sep 21, 2009 | 08:03 PM
bassboy's Avatar
bassboy
no problem
bassboy
Old Sep 27, 2009 | 01:43 PM
Dicko&Vacant
finally got round to trying what you said mate and it works fine on all settings so is the head unit kaput?
Old Sep 27, 2009 | 01:53 PM
BigErn's Avatar
BigErn
just use an ignition live as a remote live instead
Old Sep 27, 2009 | 01:55 PM
BigErn's Avatar
BigErn
just a thought but you havent just fitted it and its stopped working have you? Someone I know had mistakenly used the wire for electric ariel as remote live so it was fine when the radio was on (powered to send ariel up) but as soon as you put it on cd (power to ariel off) it wasnt working.
No it wasnt me and yes I did take the piss out of him
Old Sep 27, 2009 | 04:58 PM
Dicko&Vacant
no its been in a while working fine BigErn
Old Sep 28, 2009 | 07:45 PM
bassboy's Avatar
bassboy
then definately suspect the headunit...for a temp measure (or perminant if you like) you can wire the remote lead to a perminant supply and run it with a switch, that way you can turn the amp on and off as you like
bassboy
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
