Music & Car Audio Chat Most of your cars have a great sound system and you love music yeah? Discuss these things here...
Setting up an equalizer......
Old Aug 10, 2007 | 10:00 AM
Redeye Jedi's Avatar
Redeye Jedi
Default Setting up an equalizer......
Looking for some help setting up the equalizer on my pc! This is something ive never known how to do, obviously u can play around with it and get it sounding ok but id appreciate knowing how to do it properly and what parts of it effect which part of the sound. Its not a full on seperate equalizer as you can imagine, just the one which is part of Itunes, but id assume that once you can set one up, they are all fairly similar in principle!
I listen to alot of Drum & Bass, Hard House, Hip Hop, and Breakbeat so most of the stuff has alot of Bass! I know you can use the pre-set functions i.e Jazz/Rock etc but none of them sound that great and id prefer to have it fully customised.
If it helps, the speaker set up i have is also quite simple! 2 x satellite speakers and 1 x small sub. Nothing special but does an alright job, would just like to get the most out of what ive got!
Old Aug 11, 2007 | 04:36 PM
biglee's Avatar
biglee
Audio specialist
an EQ is there for YOU to tune the sound how YOU want it... no-one can tell you how to do it....
nuf said
Old Aug 11, 2007 | 10:25 PM
djmillsy's Avatar
djmillsy
Fife Radge
yep ive either got 2 speakers on mine or ive got 8 and a sub on it and i run 2 equalizers on mine but as said you can only set it to how you want it
Old Aug 14, 2007 | 11:07 AM
Redeye Jedi
nuf said
So no one can tell me how the individual settings effect the sound that is produced? Ive tried different settings to try and find a sound that is what i want but its not working!
What parts of the scale relate to what sound, i.e bass/treble etc.......
Old Aug 14, 2007 | 03:35 PM
djmillsy's Avatar
djmillsy
Fife Radge
i see where you coming form i dont know what they are just play about with them and see what they do
Old Aug 14, 2007 | 07:35 PM
_DAN_'s Avatar
_DAN_
Yoon
I've set mine to this.
Seems to work well on a varied selection of music.
Old Aug 14, 2007 | 08:24 PM
Ade's Avatar
Ade
Fast Ford snapper
Can't beat a big 'V shape'
Old Aug 15, 2007 | 07:46 AM
biglee's Avatar
biglee
Audio specialist
oh dear, a big smiley face.... not good...
from a professinal point of veiw you should allways cut frequencys never boost as this can hinder your system, like useing more of its power o/p to a certain frequency, this is not good... you should listen to your system flat to start with, all the faders at the center, then push each one indervidually and see which ones your ears like and dont like, the ones you do like leave in the center and the ones you dont like move them down untill they sound right for you... as i said there is no real way of setting an eq up but you can follow guide lines on how to set it for your ears, if you end up with a sort of flat line with a few frequencys dropped out then your on the right track to having your system right in the first place, if your find yourself taking loads of frequencys out then you will ned to look at your set up to find a good start.... on all my systems i dont use eq's as they are right in the first place...
Old Aug 15, 2007 | 11:36 AM
_DAN_'s Avatar
_DAN_
Yoon
Just had another little play using Lee's advice.
Alot cleaner sound, but still got some depth and plenty of bass when needed.
biglee
Old Aug 20, 2007 | 11:36 AM
Redeye Jedi
Thats more like what i wanted to hear! Thanks for taking the time to reply in such depth! Very very helpful!
Old Aug 20, 2007 | 01:11 PM
biglee's Avatar
biglee
Audio specialist
biglee
now thats better, normal ears dont like 4K, and 2.5k as this is the frequency that babies scream at to get your attention LOL
Old Aug 20, 2007 | 01:12 PM
biglee's Avatar
biglee
Audio specialist
no probs, im a professional audio engineer, so its my job to know things like this
Old Aug 22, 2007 | 09:07 AM
Redeye Jedi
biglee
So am i right in saying that the frequencies at the top, i.e 16k are the high pitched end of the scale? And the opposite end, i.e 32/64 are the bassy end? Or am i completely wrong?!
Old Aug 26, 2007 | 10:35 PM
biglee's Avatar
biglee
Audio specialist
biglee
yes mate its all in cycles per second..
ie 32 hz is 32 times a second movement... and 16k is 16 thousand hz.. 16 thousand times movement a secnd.. blah blah ...
Old Oct 12, 2007 | 03:07 PM
Thrush's Avatar
Thrush
Irritating c........
BigLee knows what he's talking about, and I agree fully with him, but I must admit to being a bit partial to the "scoop effect"
My WMP EQ settings;
Boost the low end a little for some extra "oomph" and tweek the high end up for a little sharper clairty, and leave the mid in the middle
A very simplistic way of describing how an EQ works describing sounds with words is like this.
From the low end, the lower controls change how bassy it sounds. The very end of this is pure rumble, then thump, and into punch.
Mids add/detract "tension". Boosting a mid can make, guitar music especially, music sound very "tense" and "tight". They can also add a "harshness" to the sound.
Treble frequencies add/detract "sharpness", "brightness" and "glitter". You can improve clarity with these to an extent, tho too much either way will kill your high end - either making it sound muffled (down) or over bearing (up) as too high makes it very sharp....
Old Oct 12, 2007 | 03:34 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Didn't realise boosting was a bad idea - but now I think about it, it makes sense
I'm also a fan of the 'scoop'
Old Oct 15, 2007 | 10:40 PM
Redeye Jedi
My WMP EQ settings;
You legend! BigLee's explanation was good but that was exactly what i wanted to see, answered my question 100% and now i fully understand (even more so now i have 2 opinions) how the equaliser functions and how the individual settings will effect the actual sound! Thank you kindly!
gambo08
Feb 4, 2016 10:49 PM
martynhomer01
Oct 1, 2015 12:05 AM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
20/20 vision
Sep 28, 2015 03:03 PM
Sep 28, 2015 10:05 AM
