Motorcycle Chat & Sales We do fast cars and fast bikes. Keep the bike chat and adverts in here please folks!
LED indicators
Old May 3, 2004 | 09:28 PM
Deano's Avatar
Deano
Default LED indicators
Hi I was wondering can anyone help ?
I fitted some motrax led micro arrow indicators on the rear of the bike today but I think something maybe wrong as they flash twice the speed they used too !?
This is also affecting the fronts aswell ( standard ones ) , all the bulbs work fine though its just the speed Im concerned about ? Is this normal behaviour for the smaller LED indicators ?
Thanks Dean
Old May 5, 2004 | 10:39 AM
Farmer Giles's Avatar
Farmer Giles
The rate the indicators flash at is governed by the wattage of the bulbs in the circuit. The LEDs you have fitted will have a lower wattage than the bulbs you replaced them with hence the faster flashing.
When you fit LEDs all round you need to replace the flasher relay with a different one but as you have only replaced the rear indicators you probably need to solder a resistor in series with the rear indicators to effectively increase the power needed to make them work and that will slow the flash down again. As to what rating of resistor you need I don't know I am afraid but the above is deffo your problem.
Martyn
Old May 5, 2004 | 02:44 PM
Deano's Avatar
Deano
Hello mate thanks for that , as for soldering can I get away with just twisting them together and covering with insulation tape
Ok went back to the shop and was given another set which came with the resistors this time , easily wired them up BUT the problem is STILL there even with the resistors in place !!!!!!!!!!!!!
I knew I should have just bought some bloody smoked ones instead
Old May 6, 2004 | 08:54 AM
Farmer Giles
If the resistors were the right rating and fitted correctly then I don't know what else you can do.
Maybe get the LEDs for the front and get a new flasher unit to compensate.
Alternatively just go back and buy the bloody smoked ones
Martyn
Old May 8, 2004 | 07:50 PM
Deano's Avatar
Deano
shit shit shit shit
Fitted some LED fronts today and its still flashing like a rabbit on speed
Do I have to change a relay now or something
Does look nice though maybe I should just put up with it
Old May 8, 2004 | 07:52 PM
Deano's Avatar
Deano
Oh and if anyone knows of a cheap OHLINS rear shock for a 95 blade give me a shout
Old May 10, 2004 | 01:08 PM
Farmer Giles
Deano,
If you've got LEDs all round you will need to change the relay as the old one will be rated for the old buld wattage.
Get youself on here......
www.mcnninjas.co.uk
... and ask about it. Many people on there have done the same and they are quite a friendly bunch, bar a bit of piss taking as you ride a Honda
Martyn
Old May 10, 2004 | 04:22 PM
Deano's Avatar
Deano
Oi whats wrong with Hondas ?
The blade is the original superbike
Ok have registered and asked my question although I kept my bike choice a secret
Old May 11, 2004 | 12:56 PM
Farmer Giles
I think you blew it with your username though
I hope they can help you abit more than I did.
Martyn
Old May 11, 2004 | 04:06 PM
Deano's Avatar
Deano
No shit
Old Jul 4, 2004 | 08:15 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
aye hondas need to have the reley changed ,,me m8s vfr was the same,,
Kam B
Sep 24, 2015 10:40 AM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
