Abba Superbike Stand, Paddock Stand Race stand lift
On EBAY now:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE:IT&ih=001
Si
As per the pics- Abba paddock stand. This one is used - see pic 2 for the only slight damage. Still works fine, and is going to be far cheaper than a new one that does exactly the same job!
Comes with a fitting kit to suit a Kawasaki ZX6R J1 (and most likely most other Kawasakis of the same era). New fitting kits for any other bike can be bought from www.abbastands.co.uk
Some info on this fantastic piece of kit:
abba superbike stand
No more hassle working on bikes with no centre stand or struggling with the awkward, tedious and risky balancing act required to use a conventional paddock stand on your own. The abba Superbike Stand is a total one person operation sports bike stand that fits onto the swing-arm pivot of the motorcycle. The stand is fitted to the bike when the bike is leaning on its own prop stand, so you do NOT have to hold the bike up at any time while fitting the abba supebike stand unlike conventional paddock stands, the bike can then be lifted using the integral telescopic extension lever. Because the abba superbike stand picks up in the "centre" of the bike on the swing arm pivot it can be pivoted back and two wheels can be suspended off the ground at the same time, with the aid of your own prop/jack or the abba front lift, when two wheels are lifted off the ground in this way this is totally off loading the shock/fork springs, the shock and linkage can be removed. The abba superbike stand enables much more work to be carried out on the machine than a conventional paddock stand.
10 Reasons why to buy a abba superbike stand...........................
Totally safe, 1 person operation-guaranteed
Totally secure as the abba superbike stand locks onto a solid point, unlike a conventional paddock stand.
Rear suspension is not under compression. There is no unnecessary load on the shock. The shock can be removed.
The abba superbike stand fits both single sided and twin sided swing arms, there is no need to change your stand if you change your model of bike.
The abba superbike stand has fitting kits designed specifically for your bike.
With the abba superbike stand both wheels can be suspended off the ground at the same time by using the abba front lift or your own jack/prop.
The abba superbike stand will not scratch any part of the swing arm, unlike some conventional paddock stands.
All abba products are made in the UK and come with a full guarantee.
No bobbings etc. needed to be fitted - the bike stays totally standard.
Swing arm can be removed with an adapter (optional).
Si
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
The Youth.
30-09-2015 09:59 PM
