General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
if you're starting from a shell it's a piece of piss, need a 2wd front subframe, 2wd front hubs ( i have some 3 door ones for sale ) 2wd rear beam, 2wd sump, thats about it i think?
And a T5 gear box, 7.5 inch diff, larger half shafts, larger stub axles, 4 pot calipers, different prop, different exhaust as the 4x4 crosses under gearbox, solid rear disk and callipers, brake master cylinder is different, aswell as what is listed above
and them bit's aswell
the 4wd master cylinder is different but better to use really as the master cylinder is further away from the turbo/exhaust,
the gearbox cradle is different iirc? but will bolt striaght to the floor, no welding or cutting needed mate
o i you'll love it owd lad,i got mine back t'other day and immediately kicked its head in on a r/b,thing is you get overexcited and start getting closer to the kerb....
thats what ill be like i know, gonna have to be carefull i think might start with a stage 3 or something lol
Not even close i`m afraid....
Jimbo, you will need this part number: 6177696
That cradle is a direct replacement to fit the 2wd box into a 4x4 tunnel...... the mount sweeps up very close to the speedo cable, so the best way to sort it is to drill a small hole into the mount and pass the cable straight through into the speedo drive....
Apart from that it`s a piece off piss
apart from ford, who else would sell tis cradle? cheers
you sir, are a star would av been a pisser me holding up a t5 trying to get that all bolted up will have to get one
