NOISE FROM ENGINE???HELP?????
Old Jan 29, 2006 | 10:22 PM
COSSIE 1's Avatar
COSSIE 1
Default NOISE FROM ENGINE???HELP?????
Ive got a series 2 erst when i rev the engine it sounds fine when standing over the engine but when u sit inside and rev it or drive it u can hear a highish pitched whine which gets louder the more its revved which sounds similar to electrical whine that u hear when ur stereo is on(btw i havent got a stereo in the car) and u get interferance, its the only way i can describe it, the water temp is fine, it starts and idles perfect the alternator belt was a little loose and i was hoping it was that but i tightened it up this afternoon and its still like it ,
could this sound be caused by a split pipe? or any other ideas what it could be...cheers pp
Old Jan 29, 2006 | 10:36 PM
AndyRST's Avatar
AndyRST
Has the cam belt been changed recently ? If so check its not been done up too tight, that can cause a whine noise. Also have you over tightened the alternator belt ?
Does the whine increase as the engine revs increase ?
Old Jan 29, 2006 | 10:47 PM
COSSIE 1's Avatar
COSSIE 1
yeah sort of ,
and how difficult a job is it to adust the cambelt??
is this whining noise a known thing??, cheers
Old Jan 30, 2006 | 07:35 AM
COSSIE 1's Avatar
COSSIE 1
anymore ideas peeps, would like to have a look at it today as im off work
Old Jan 30, 2006 | 10:34 AM
st3v3's Avatar
st3v3
take the alternator belt off altogether,that way you would be sure that its not the belt or the alternator,obviousley put it back on after
Old Jan 30, 2006 | 11:23 AM
COSSIE 1's Avatar
COSSIE 1
good idea mate ill do that , is the overtightening of the cambelt common then??
Old Jan 30, 2006 | 11:50 AM
AndyRST's Avatar
AndyRST
Not common, but i have heard a RST with a cam belt too tight and it made a whine noise
malkiemac3579
Jul 14, 2017 12:10 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
