bleeding cooling system on rover 214 k series
Old 26-01-2006 | 08:23 PM
S1 Lee's Avatar
S1 Lee
Default bleeding cooling system on rover 214 k series
my missus has a rover 214 96 plate and the top hose burst, whats the correct process for bleeding the cooling system, i was messing with it for 2 hours today with no joy.
i have now read that you fill the header tank up slowly, with the bleed screw out with the engine off.
is this correct?
Old 26-01-2006 | 08:26 PM
Cowboi's Avatar
Cowboi
not to sure on bleeding it mate. and i know its off subject. but i do know that u should do it often. as the water channels in the k series engine are pron to blocking up and the doing head gaskets.
just thought id mention it so that once u do find out how to do it u can do it more often to avoid having a weekends work of a head gasket.
good luck
Old 26-01-2006 | 08:28 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
these are a joke, take fookin ages to do
Old 26-01-2006 | 08:41 PM
S1 Lee's Avatar
S1 Lee
tell me about it.
the thing is, they must have a way of bleeding them when they build em, so it must be possible.
Old 26-01-2006 | 09:54 PM
S1 Lee's Avatar
S1 Lee
bump
Old 26-01-2006 | 10:03 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Originally Posted by S1 Lee
bump
remove the thermostat, drill a 2mm hole through it at the top and it will never have any problems with bleeding again
Old 26-01-2006 | 10:39 PM
S1 Lee's Avatar
S1 Lee
i did read that somewhere as well.
seems like a lot of hassle just to bleed it easily though, is that the only way.
Old 26-01-2006 | 10:56 PM
Doug's Avatar
Doug
As martin said unless you wanna have your arse raped purchasing a vac fill system.
Old 27-01-2006 | 09:08 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
According to the Rover Service Manual...this is what is states.......
Service repair no - 26.10.01
Refill
1. Flush system with water under low pressure.
CAUTION: High pressure water could damage the radiator.
2. Connect bottom hose to radiator and tighten clip.
3. Prepare coolant to required concentration
4. Remove bleed screw from coolant rail.
5. Fill system slowly until a steady flow of coolant
is emitted from the bleed hole in coolant rail.
6. Fit bleed screw to coolant rail and tighten to 9 Nm.
7. Continue filling system until coolant level reaches ’MAX’ mark on expansion tank.
8. Fit expansion tank filler cap.
9. Fit air cleaner.
10. Start and run engine until radiator cooling fan operates.
11. Switch off engine and allow to cool.
12. Check for leaks and top-up coolant to ’MAX’ mark on expansion tank.
I know when I did the headgasket on my girlfriends metro it was an absolute TW*T to bleed - I was there a while too!!!
With the 8v 1.4 engine there is a little ball bearing valve on the left of the inlet manifold that can block up & cause bleeding/cooling issues - best thing is just to shove something through it to remove it completely - I presume yours is the 16v version so it shouldnt matter!!!
Why did the top hose blow off.....was it just loose or could it be a sign of something else....
Old 27-01-2006 | 06:43 PM
S1 Lee's Avatar
S1 Lee
top hose was split where the jubilee clip was.
Old 17-02-2006 | 09:25 PM
S1 Lee's Avatar
S1 Lee
sorted it out in the end.
after hours spent trying to bleed it the dreaded white smoke started billowing out the back, head gasket gone.
took the head off, got it skimmed and pressure tested. replaced the thermostat as a matter of caution and also drilled the new one.
banged it all back together. no messing around bleeding needed. the hole in the stat did its job. running as sweet as a nut now.
thanks for the advice.
Old 17-02-2006 | 09:27 PM
Martin-Hadland
told you glad it's sorted
Old 17-02-2006 | 09:31 PM
S1 Lee's Avatar
S1 Lee
as i said mate thanks for the advice.
i never doubted your advice, just the thermostat looked like a right bitch to get to, but was a piece off piss with the head off.
thanks again.
01-11-2015 07:53 PM
AJC
08-10-2015 12:09 PM
Kiran1600E
11
02-10-2015 12:35 PM
AJC
01-10-2015 07:47 PM
XR4
Ford XR Range
01-10-2015 01:46 PM
Quick Reply: bleeding cooling system on rover 214 k series
