Identifying a Maram shafted turbo? update with pics
Old 25-01-2006, 09:32 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Default Identifying a Maram shafted turbo? update with pics
i got a T34 with .63 ex housing on it, and tonight i took the ex housing off.
the shaft has 2 something 7 stamped on it, i cant tell the middle number cos there is a hole in the end of the shaft.
now ive heard that maram shafts are 247 - is that correct?
it looks like either 217 or could be a 4 but i can only see the the very top of the middle number, but its closer to the 7 than the 2 if that makes sense lol?
i know maram shafts are non magnetic, but i aint got a magnet to check lol
Old 25-01-2006, 09:41 PM
bud-weis
Football Cwazy
bud-weis's Avatar
my .63 housing has no markings whatsoever on the turbine wheel? so i guess yours must be maram'd up just run anti lag and see how long it lasts
Old 25-01-2006, 09:43 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Maram Shafts are non magnetic as you say.. Also they are 247 not 217
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
may have 247 stamped on the end,or and isnt magnetic,
Old 25-01-2006, 09:44 PM
Micky The Finn
Former Sponsor
beat me to it.
Charlie Chalk
Unknown.
Old 25-01-2006, 09:48 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
guess i need a magnet lol
my mate said his T34 didnt have any markings at all on it.
ill try and get some pics up but it wont be till the w/e
fookin bonus if it is.
PS will be running ALS regardless lol
oh, also, one more thing lol
on the main body bit of the turbo, it has a silver coloured screw in it, looks like a flat blade screwdriver insert into a splined outer bit thats screwed into the cast bit, what is it for? - no sense again - deffo need pics
Old 25-01-2006, 10:02 PM
markk
markk's Avatar
thats where the font insert has been fitted when the restrictor was removed
Old 25-01-2006, 10:07 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
you what?
got any pics at all?
i bought it having supposedly covered 100 miles.
but it does have FOOK ALL play in it, and looks like its pretty new.
so cant imagine its been used for rallying.
so could it be a maram shaft?
i need to learn lots about turbos asap
Old 25-01-2006, 10:10 PM
Charlie Chalk
Unknown.
For this blue thing = Restrictor
Old 25-01-2006, 10:11 PM
Micky The Finn
Former Sponsor
i once did 16 miles with a brand new one and blew it to peices,rather the T6 als did.
Old 25-01-2006, 10:12 PM
Micky The Finn
Former Sponsor
how did you get the gorrila to stay still so long while you rested the turbo on its knee?????????
Old 25-01-2006, 10:13 PM
bud-weis
Football Cwazy
bud-weis's Avatar
did any T34's come with different sized compressor housings?? cos mine seems bigger than a mates ( just at the inlet throat ) i know it's bigger because we tried fitting a boost hose off his onto mine and it wouldn't go??
Old 25-01-2006, 10:14 PM
Charlie Chalk
Unknown.
Not my leg, Ask Red16
Old 25-01-2006, 10:15 PM
Charlie Chalk
Unknown.
Some are T3 size 60mm iirc some bigger 70mm i think, Not sure
Old 25-01-2006, 10:18 PM
RobCarden
358bhp
RobCarden's Avatar
mines like that - i had to use rs500 hose - same size as the rs500 intercooler outlet
Old 25-01-2006, 10:20 PM
markk
markk's Avatar
so youve answered al your questions !!
it was a motorsport turbo, so you will need to have an inlet made for it
Old 25-01-2006, 10:24 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
[img]
rad its not like that on the inlet, its round all the way err round
what i meant was the main body the shaft goes in, not comp or ex housings, you see the oil feed in that pic, in the middle beween that and the water feed is the silver screw thing im on about. i really need pics, but aint got none yet.
Markk - still none the wiser lol
Old 25-01-2006, 10:29 PM
markk
markk's Avatar
that blue bit needs to be removed pal , have a look at it internal diameter, it will be 34mm, as per rallying regs, so it needs to be opened up mate, to more like 60mm, other wise you'll have a hell of a problem
Old 25-01-2006, 10:30 PM
Micky The Finn
Former Sponsor
or lots of torque!!!!!!!!!!!!!!!!!!!!!!1
Old 25-01-2006, 10:33 PM
markk
markk's Avatar
well you know what my answer would be, i actually prefer an engine that will accelerate within the current millenium
Old 25-01-2006, 10:40 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
no no, you dont understand what im trying to explain.
mine doesnt have a restrictor, its got a normal looking inlet bit, ie about 1/2 an inch longer that the pic rad put up if you ignore the blue restrictor.
the silver screwy bit im on about is between the oil feed and the water feed, tapped into the main housing bit that hte shaft passes through.
as i said, a pic will speak a million words lol, but i aint got any pics...
Old 25-01-2006, 10:43 PM
markk
markk's Avatar
get the pics
Old 25-01-2006, 10:44 PM
Charlie Chalk
Unknown.
Pics
Old 25-01-2006, 10:47 PM
Micky The Finn
Former Sponsor
pics of your sister will be better,or cousins etc....
Old 25-01-2006, 10:51 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
no sisters sorry, and counsins are male too
i guess its one for dave PICS OR STFU
Old 26-01-2006, 02:47 AM
CliffRS4
CliffRS4's Avatar
I think you might mean that it has a space for an Exhaust gas temperature or lambda sensor?
Old 26-01-2006, 07:52 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
cliff, quite possibly mate.
the ex housing has a bolt in it,about M10 or 12 so i guess thats for lambda?
but the one in the main housing im not sure of
defo defo need pics
Old 26-01-2006, 09:03 AM
Tony Ryan
Tony Ryan's Avatar
You can usually see the 247 stamp in these quite easily , heres one of mine in a T4
Old 26-01-2006, 09:11 AM
That fits his description of "looks like it might be a 1" perfectly
Old 26-01-2006, 05:39 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
cheers Tony, it does look kinda like that but id say the middle mark is a bit closer to the 7 than the 2.
ill try and get some pics tomoz but not sure if ill get time to go over where it is.
also the numbers are nearer the middle of the shaft too.
and the blades look different but if its a T4 then i guess they prolly would lol.
Old 29-01-2006, 11:03 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
ok, we have some pics now lol
and this is the silver screw thing i was on about that goes into the oil way by the shaft. whats it for?
compressor wheel
and comp housing says .60 on it inside, also says M27 on the outside.
Old 29-01-2006, 11:04 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
oh yeah, and the shaft and wheel are NON magnetic
Old 29-01-2006, 11:05 AM
markk
markk's Avatar
that my friend is a pukka group a turbo !!
it is a mar-m shaft, and the little blank you have is for measuring core temp and shaft speed
Old 29-01-2006, 11:07 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
sweet, cheers mark
how do they measure shaft speed tho? i didnt see any lobes or anything on the shaft?
Old 29-01-2006, 11:10 AM
markk
markk's Avatar
its measured for optimum operating speeds and so as not to overspeed the turbine, as for how, the last one i saw was an optical sensor on it but i never saw what they had on the shaft to pick up from, could be the gap in the front ring
Old 29-01-2006, 11:15 AM
costina
Live long and prosper!!
costina's Avatar
How much are these worth in good condition?
I paid £200 4 mine cheaper than a t3 recon
Fudgey
Baby Cheesus
Fudgey's Avatar
cool, thanks very much mate.
im pretty chuffed now, only paid £400 for it, and its supposedly only done 100 miles, non exchange too
Old 29-01-2006, 11:22 AM
markk
markk's Avatar
costina
try nearer £1000 pal for a good un !
fudgeass
you stole it !
Old 29-01-2006, 11:38 AM
costina
costina's Avatar
GOT A BARGAIN THEN?
Quick Reply: Identifying a Maram shafted turbo? update with pics
