escos ready to be repaired :)
#43
1 Post
hopefully start in 2 weeks time - not gonna temp any sort of fete and order anything in advance - will fully strip, clean and diagnose , then clen again, paint and rebuild - i'm goona go for a world first... the first YB not to leak oil form anywhere....
#45
Cant go wrong with a clio 172/182 IMO
I've had mine coming up 4 months now, and cant fault it at all
Will average 28+ MPG however hard you drive it
Average around town is between 32-34
And 38mpg on the motorway is easily done, 40 if ur drive like a grandad lol
Full service at Renault just cost me under 300quid
All parts are pretty cheap
Lots of aftermarket parts, and are all pretty well priced
Fun to drive, comfortable enough to keep most people happy,
Plus got all the extra's like leather, climate control, all electrics, 3 proper rear seat belts, 3 rear headrests, 16" alloys, cd player, traction control etc etc
And build quality sont seem to be a issue on mine, its spot on
Plus there a TOTAL bargain at the moment, i payed under 7k for mine when it was 22 months old (1 owner, full history, mint condition), meaning it still had the balance of the 3 year warrenty aswell
Any questions just ask mate
But in general u cant go wrong with one
EDIT - Forgot to add, they aint to slow either, mine hits 60 in around 7 seconds dead, and the cups will do 60 in just under 7
#47
1 Post
adding up as we speak.....
before i find anything broke - a full strip down will require the following...
( a few bits added that i need at the same time (light lenses, stalk and rear bearing etc)
can anyone else think of anything else obvious...?
cambelt grp A Ł27.50
headgasket GRPA Ł60.00
head bolts set Ł22.50
inlet gasket Ł2.40
plenum gasket Ł6.95
water pump gasket Ł1.15
o ring Ł2.50
oil from oilman Ł45.00
half moons x2 Ł8.00
front crank seal Ł2.50
rear main seal Ł15.00
turbo drain gasket Ł1.00
rear prop bearing Ł18.00
front fog light X2 Ł44.00
sidelights Ł20.00
new indicator stalk Ł45.00
header tank Ł25.00
upto about 350 beofre i actually do anyting - bt as i say, not actually gonna order anyting until its in bits - might find that there is no point in reparing it - as they say yuo cant polish a turd might end up havingto buy a complete lot then break up my good bits ..
inlet gasket Ł2.40
plenum gasket Ł6.95
o ring Ł2.50
half moons x2 Ł8.00
sidelights Ł20.00
header tank Ł25.00
#48
Glad you`ve seen sense mate...
The offer of help was genuine by the way... I hate seeing people struggle and thinking they are backed into a corner when a bit of outside help would sort the problem easy....
Ask Sticky,he was getting down in the dumps with his but a couple of visits to the House of Pain and it`s good as new...
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
