dump valves.
Old Jan 23, 2006 | 05:07 PM
Robert_Cox's Avatar
Robert_Cox
Default dump valves.
im about to buy a FRS and the first thing i wanna do is fit a dump valve. what is the bet make to choose? i was also wondering wot the difference is between dump valves that do a normal choof lie a bailey dump valve and the other type that flutters??? been baffling me for ages wot the difference is? can any one help me??? lol thanks.
Old Jan 23, 2006 | 05:08 PM
TIFF's Avatar
TIFF
Chasing Radders
Why do you want a Dump Valve???
Old Jan 23, 2006 | 05:15 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
don't do it mate.......
Old Jan 23, 2006 | 05:42 PM
big_wig_074's Avatar
big_wig_074
oh jesus! that fluttering noise is when u DONT have a dump valve!
Old Jan 23, 2006 | 06:17 PM
D2EVS's Avatar
D2EVS
dont fit the dump valve you usually get idling probs with these on the Focus.
Old Jan 23, 2006 | 06:18 PM
D2EVS's Avatar
D2EVS
You should get the flutter with just an induction kit - should !
Old Jan 23, 2006 | 06:20 PM
Thrush's Avatar
Thrush
Irritating c........
Yes, the flutter (or "chatter" as it is known) is when you DON'T have a dumpvalve
For info please refer to my earlier post in someone elses thread
Originally Posted by Thrush
Chatter occurs when escess, built up charge gases get stuck between the inlet butterfly and the turbo when you snap the throttle shut when changing gear of lifting off for example.
If you have a dump valve (either to atmosphere or a recirc type that vents backinto the airbox) these gases are dispelled either to atmosphere or re-circulated back to the airbox.
If you have neither, the gases are stuck, If there is enough force and enough gas, they hit the now blocked off throttle butterfy, turn round and go the opposite way down the charge carrier. They exit through the turbocharger and the noise you hear, the "chatter" is the sound of the excess charge air being "chopped" by the turbine blades.
So, you will get more chatter if you have no dumpvalve at all. There is an argument as to at what point you NEED a dumpvalve due to the mass airflow going backwards through the turbine blades causing turbo-stall and possibly damaging the bearings and shaft.
Old Jan 23, 2006 | 06:27 PM
boXXer's Avatar
boXXer
GASH!
Dont do it. Stick a decent filter on it, and run no dump valve. Will sound soo much nicer.
Old Jan 24, 2006 | 01:46 PM
Robert_Cox's Avatar
Robert_Cox
im surprised at the replies there? why not get a dump valve? i think it sounds absolutely awesome!! and with regard to the chatter im sure im on about summin else. my friend had a recirc valve onhis seat cupra and that made a noise like a pigeon rather than a choof. im sure that werent gases hitting the blades fo the turbo??? it seems the focus is pretty poor wen cold on tickover ne way. my fathers and my bros often cut out wen cold.
Old Jan 24, 2006 | 01:48 PM
DaveEscos's Avatar
DaveEscos
good for you pal!
get a dump valve
they rule!
Old Jan 24, 2006 | 01:49 PM
Kev.H's Avatar
Kev.H
dont bother getting a dump valve the FRs has a re ciculating valve anyways get the K&Ng2 and it makes the standard re circ valve chuff like a atmospheric dump vavle and has the added bonus of not stalling your car
Old Jan 24, 2006 | 01:52 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
the chattering/fluttering noise is air coming back out the turbo inlet when coming off throttle.
a dumpvalve will reduce if not remove that noise.
only reason some people think that a DV does it is when they fit aftermarket dumpers that have an overly strong spring in it, and that means not enough air comes out the dumper, so lots more come out the turbo inlet than before, and hence the chattering noise.
trust me, been there, done this, 6-7 years ago up until today, as have countless others here.
Old Jan 24, 2006 | 01:56 PM
Stu @ M Developments's Avatar
PassionFords Creator
The cars got an airflow meter chaps, you cant take the dump valve off FFS Take care out there people....
Old Jan 24, 2006 | 02:00 PM
RichardPON's Avatar
RichardPON
Hmmmmm... don't seem to recall Rob's Focus ever stalling, and that was hardly standard!
Old Jan 24, 2006 | 02:02 PM
Kev.H's Avatar
Kev.H
well rich some do some dont so for the hassle it could cause... just either keep the re circ unit or uprate to another aftermarket re circ unit fit a G2 K&N and it dumps anyways
Old Jan 24, 2006 | 02:05 PM
RichardPON's Avatar
RichardPON
Really?
I thought they only stalled when you fitted the wrong dump valve
Old Jan 24, 2006 | 02:10 PM
Kev.H's Avatar
Kev.H
Really?
yeah wrong dump valve that must be it read lots of peeps having problems that all just TRYING to help the guy
Old Jan 24, 2006 | 02:21 PM
RichardPON's Avatar
RichardPON
Don't get mardy you miserable bastard.
Just don't remember any dump valves causing FRS to stall when we used to fit them.
Would hardly be acceptable to fit a product on a customer's car that did that now would it?
Old Jan 24, 2006 | 02:28 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Wrongly specced/springed dumpers do make AFM equipped cars stall or at least massivley overfuel when coming off the throttle, really common on JapCars.
Kev.H's Avatar
Kev.H
maybe you should spend more time on FRS forums just saying what ive seen
I havent fitted a DV but I assume you remove the factory item near the airbox if you do maybe peeps are running two
Old Jan 24, 2006 | 02:38 PM
RichardPON's Avatar
RichardPON
Ooops
True about the Jap cars though - people always harp on about VTAs on MR2 turbos with AFM, but mine has caused no stalling.............
Old Jan 24, 2006 | 02:51 PM
Kev.H's Avatar
Kev.H
Ooops
you sound like Mike never assume only post if you have facts blah blah
I was just offering the guy another route which I KNOW works
Old Jan 24, 2006 | 02:53 PM
RichardPON's Avatar
RichardPON
.. and your route isn't wrong either......
I just like winding people up - you should know that by now.
Anyway, why we harping on about FRSs - the new ST is far superior etc etc
Old Jan 24, 2006 | 02:54 PM
Daveyboy's Avatar
Daveyboy
that looks like the standard MikeR configuration of smileys as well Rich you sure you aint turning into Mike?
Old Jan 24, 2006 | 02:55 PM
RichardPON's Avatar
RichardPON
That was the point Jackie - never miss a thing do ya
Old Jan 24, 2006 | 02:56 PM
Daveyboy's Avatar
Daveyboy
hence the at the end bollockchops
Old Jan 24, 2006 | 03:06 PM
Kev.H's Avatar
Kev.H
and both r better than your shit box MR2 ringburn lover
Old Jan 24, 2006 | 04:43 PM
Robert_Cox's Avatar
Robert_Cox
wots the difference between a gen 2 k&N and a normal 57i kit#? price? power? and wen we say it choofs with it, how loud r we talkng???
Old Jan 25, 2006 | 08:12 AM
Kev.H's Avatar
Kev.H
they dont do a 57i kit for the focus rs its standard air box and panel filter (which k&N do make) or K&NG2 kit
difference er power didnt really notice noise defo louder price double
cossie09
Oct 11, 2015 06:29 PM
DAZZER
Sep 30, 2015 08:43 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
