Intercooler fluid
Old Jan 22, 2006 | 10:48 AM
spark's Avatar
spark
Default Intercooler fluid
Just checked mine and the pinky fluid that should be in there is lower than it should be,
What stuff do i need to buy for it?
Heres what i mean
Do Halfords sell this?
Old Jan 22, 2006 | 10:50 AM
Billabong's Avatar
Billabong
Intercooler fluid? Take a pic of the top of the cap, probably power steering fluid...... what car?
Old Jan 22, 2006 | 10:51 AM
spark's Avatar
spark
Its for an RS Focus
Its not powersteering as thats on the other side of the engine bay.
It has a picture of a book on the lid. I reckon its antifreeze and water but i wasnt 100%
Old Jan 22, 2006 | 10:52 AM
twitchyrear's Avatar
twitchyrear
i thought intercoolers were air to air???
Old Jan 22, 2006 | 10:53 AM
Billabong's Avatar
Billabong
I thought I recognised that blue pipe - my bad . I'd imagine it is water and antifreeze, but it should say exactly what in the owners manual.
spark's Avatar
spark
Cant find my manual lol
Old Jan 22, 2006 | 10:54 AM
andyt's Avatar
andyt
me too and only chargecoolers have fluid
Old Jan 22, 2006 | 10:56 AM
ballin's Avatar
ballin
yeah thats chargecooler - same as rad mate water+antifreeze.
id just top it up with antifreeze personally
Old Jan 22, 2006 | 10:58 AM
Billabong's Avatar
Billabong
FRS has a similar setup to large tiurbo EsCos - air to air / chargecooled.
EsCos used it's own cooling system, whereas I *think* the FRS is on a seperate system, but still likely to be water/antifreeze mix - not my car though, so hopefully another FRS owner will confirm.
EDIT: I wouldn't personally use just antifreeze (unless it's some special formulation for this specific purpose) as antifreeze on it's own isn't a good idea for several reasons....
Old Jan 22, 2006 | 12:01 PM
Micky's Avatar
Micky
What reasons???? Regards Micky
Old Jan 22, 2006 | 02:09 PM
Billabong's Avatar
Billabong
Corrosion, plus the fact the most antifreeze needs to be mixed with water to allow lower freezing and higher boiling points.
Old Jan 22, 2006 | 03:03 PM
DelboyTurbo's Avatar
DelboyTurbo
i thought coolant prevents corrosion......AFAIK the only reason not to use pure antifreeze is high concentrations can damage seals, and it has poor heat latency compared to water.
Old Jan 22, 2006 | 03:05 PM
Billabong's Avatar
Billabong
Depends on the formulation of the antifreeze, but how many cars run 100% antifreeze.....
We're both saying the same thing on that one.
Old Jan 22, 2006 | 05:09 PM
ballin's Avatar
ballin
i didnt say neat antifreeze throughout, but the small amount it needs topping up i would use neat
Old Jan 22, 2006 | 05:26 PM
Billabong's Avatar
Billabong
Forgot about the topping up bit ,doh! Was talking more in general and slightly off topic .
Old Jan 22, 2006 | 05:29 PM
Big Ad's Avatar
Big Ad
Lol its a charge cooler and use normal coolant that goes in the header tank mate
Old Jan 22, 2006 | 05:54 PM
spark's Avatar
spark
Cheers Ad
Got some sorted, noticed that the good old ford clip was allowing it to escape, will need to get it changed to a Jub clip sharp!
Old Jan 22, 2006 | 06:22 PM
Big Ad's Avatar
Big Ad
thats exactly why I think intercoolers are better, no fluid, just air.
See if you had carried on driving and didnt notice you could have done some damage
Old Jan 22, 2006 | 06:26 PM
spark's Avatar
spark
Glad i check the car regular
Old Jan 22, 2006 | 06:28 PM
ballin's Avatar
ballin
err not really. act's would rise yeah, but the FRS management is more than capable of dealing with that
Old Jan 22, 2006 | 06:31 PM
Big Ad's Avatar
Big Ad
Well it would only retard the timing to produce less power but long term it would
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
