How CAN you improve a standard VC cosworth diff???
As it sounds really, would love a ATB in my car but just cant afford it... my diff was re-built/re-bearing'd/sealed recently, but i never checked the LSD which is Handy it works but have been told Not anywhere near it should be..... I do have however a box of about 4/5 old LSD's with missing sun/planet gears .... and was thinking can you just put some more plates in it from the other diffs?? So there it is .. CAN I? if not What Can i do?
cheers
cheers
you cant improve shit - viscous units are just that - shite - and no you can change plates - cause there are non ( ie friction plates) its a case of having the viscosity changes and the fluid pumped back up, makes them even worse than std - ok for standing starts - complete crap for understeer when hot
hth
hth
i just thought they had loads of paper thin plates as i took 1 apart and there was fookin loads of these thin plates in it along with the gloopy stuff just thought about stuffing more into mine and touque'n it up????
apart from that (if it can be done) what the best route to take ....
it has to be pressurised by a specialist - have a chat with bernie at cts, tbh a mild increase to say 200nm/s would be ok for a road car and make quite a decent enough diff - but you will still have the inherant 2 planet gears instead of the normal 4 hence why they break
SO where do i get a 4 planet gear one from????
or do i guess id need a 2nd morgage
Looks like its going to have to be a cheap (if they exist) ATB or plated one i think then
cheers for your comment/help
Location: *PF TERRORISTS CARTEL* Bin flocking Youngens :cry:
in other words palmer my lad, YOUR FUCKED
hope your still gona let me know when your first sprint is?
hope its goin well with the little one as well pal
rog
04-09-2015 12:10 PM
