CHARGE AIR TEMPS
i always believed best ACT on a cossie was 30-40oC, above that your start to loss power,
but most engine dyno runs i've seen run about 15-20oC for the power run.
DEYTUKURJERBS
i mean, if thats true, how come cars always feel noticably faster when the weathers fucking freezing and the charge temp is next to fuck all?
UNLESS, and this is summat i jus came up with while typing this, the cold air is more dense which makes the turbo compressor much more efficient (it will), so in turn making the car faster.
i know there are suprisingly huge performance gains from substantialy cooling the air in the compressor as ive seen detailed testing of pre-compressor water injection to achive the same results.
effictivley moves the compressor map along, makes the turbo miles more efficient.
oh, and regarding chargecoolers, they brilliant IF they and the water rad is big enough, thing is they normally way too small.
PWR chargecoolers are the tits, id run one rather than a big intercooler if poss...
http://www.pwr.com.au/pwr/index.asp
Norris Motorsport
If other engine factors remain constant every 10DegC rise in ACT gives a loss of 3%power.
The ideal inlet temp of 40DegC is not actually a myth, this is indeed the best compromise of fuel atomisation against power and has been proven by OE car manufacturers.
HOWEVER in turbo installations I disagree with this condition and find coldest is always best. The reason for this is because the extra volume of air flow causes a more turbulant flow aiding fuel distribution and atomisation.
On my own car I now run 4 intercoolers and a large charge cooler and it makes a BIG difference!!
DEYTUKURJERBS
So literally there no such thing as too cold (within reason!) like I thought?
Pics!
ive changed my 500 cooler for a jap one just got to get it to fit ,ive just purchased the erl 2d water injection mf2 kit and will be fitting this too.so with the changes carried out it will be going to the rollers again when i bring her out.it was dyno'd at 396( cant remember if charge temps were on the print out)a month before i hibernated her so im hoping to see a slight increase with these cooling mods when its at the rollers for a set up in april.
Norris Motorsport
Charge coolers are actually far less restrictive for charge airflow (i.e. pressure drop) than an intercooler because as a rule they have a large x-sectional area yet a relatively narrow core, whereas an intercooler usually has a smaller crosss sectional area and long core.
I have fabricated my own charge cooler that fits onto the outlet of the interooler before the throttle body and helps control charge temps when at low vehicle speed. At high speed the IC is more than man enough, so essentially my charge cooler takes car of charge cooling for launching and the IC controls high speed usage.
whats the best way of using the water from the water inj kit??direct into inlet pipe or srayed over the cooler??i was thinking of plumbing mine direct into my intercooler to throttle body piping. alloy pipe(not a samco)
DEYTUKURJERBS
Sprayed into the intercooler will do fuck all, youd be better off doing a big poo on the back seat o lower charge temps than doing that.
The most effective place in theory is directly after the compressor outlet of the turbo.
BUT as you have an intercooler it will lower the efficiency of the Intercooler slightly, so dont bother, let the intercooler do the first bit of cooling.
Fit it on the outlet of the intercooler.
My SX, once i get round to fitting it, will have the water injection jets in 3 different places actually.
when you say outlet of the intercooler do you mean on the 3" outlet pipe on the cooler??would there be much difference mounting it about 6 inch back towards the throttle body?? should be an easy mod to carry out though
DEYTUKURJERBS
Better having it as far away from the throttle as poss mate, gives it more time to evaporate into the boosted air, so literally on the intercooler outlet if you can.
i
It was Harvey who told me that about 3 years ago (about 40oC on a cossie)
So Why is it the norm to have water inj come on @ 38-43oC ACT? why not 20oC?
Never heard of straight after the turbo,
GOOD INFO GUYS SOMETHING TO THINK ABOUT!!!!!!
GOING TO FIT ESCORT COS INTERCOOLER(BIG TURBO)AND FIT SEPARATE PUMP AND RAD AS I HAVE LIMITED ROOM, AND DON'T WANT TO CHANGE APPEARENCE OF THE FRONT OF CAR !!!!
HOPEFULLY THIS WILL BE A BETTER SOLUTION TO KEEP TEMPS DOWN!!!!
THINKING MORE OF SUMMER WHEN ITS DRY.MORE TRACTION MORE FUN!!!!!!!!!!!!HIGH TEMPS LESS RESPONSE =LESS FUN!!
DEYTUKURJERBS
People believe that 40deg is best BS myth (they do) even tho surely they mustve felt how much better the car goes when its freezing outside.
And ABOVE 40deg is particularly bad, and if you had it set to 20 itd be on all the time as most coolers (RS500 ones especially) have a harsd time keeping temps at 40deg, never mind 20.
Theyd need huge water inj tanks the size of the fuel talks like the old GrpA Volvo 240turbos used.
WELL actually the most effective is pre-compressor so the air never gets heated so much in the first place, increasing the efficiency of the turbo, but you cant inject more than a v.small amount pre-comp or it will erode the compressor wheel over time.
i could power 2 atomiser jets,could i put 1 either side of the cooler on the outlet pipes,so cooling the air on the way in and out of the cooler??or is that overkill?
It was Harvey who told me that about 3 years ago (about 40oC on a cossie) but every dyno power run i see of his is around 15-20oC,
Originally Posted by costina
Is it any better? do you have a charge temp gauge?if so is the temp drop
a lot ? better performance etc?
cheers
Paul
cheers
Paul
1st to 200 without NOS
DEYTUKURJERBS
like said, putting it before lessens the effectivness of the intercooler. just put it directly afterwards, and change the jet size to suit your needs (ie how much more you want the charge temp to drop)
i must be misreading this, wouldnt fitting water injection after a turbo lead to condensation in the intercooler, over time ending up with an intercooler full of water?
DEYTUKURJERBS
Is tiny droplets of water that heavy and sticky that highly pressurised air moving at nigh on supersonic speed cant make it move?
Either way, id use it after the intercooler.
cheers
Paul
cheers
Paul
Testing the future
Was told charge temps too high on rollers trying to lower them time allowing
TT T38 Power
Less room in a mk 3 Steve!
i'm also using cos rad and fans !!don't want to mod the front valance!
any way got a ecs cos charge/cooler 4 30 notes
Paul
Paul
What boost and injectors you running now ?
Still have that moded prop as well
Steve.
My thoughts on the subject:
The water injection doesnt kick in at lower temps as it is a trade off. Adding water itself does not increase power. So if you already have low temps adding water will just put out the fire thus reducing power. Its only required to contain the level of power loss by stopping the temp getting any higher.
Colder is better on turbo cars. I have seen temps on some cars of less than ten degrees when run up at AVA and they have made very good bhp for the level of boost/mods. I think it was circa 210 wheels on a 1.6 rst running 12 psi with super cold intake due to awesome intercooler.
I used to run a massive chargecooler and it can work, however the hassle of all the water, pipes, radiators etc and the weight of carrying masses of water meant than any benefits from the specific latent heat of water being higher than air was traded off.
I would also run the best most efficient intercooler I could for whatever power I ran as long as it wasn't so massive as to cause lag. If your intercooler is up to the job then its such a hassle free life. No pumps to fail or leaks to spring etc.
I always want a car that runs no more than 30 degree inlet temp after tge intercooler. Seems to be a happy compromise. I wouldnt be that interested in water injection as it is again more things to go wrong, needs water all the time when in full use and is just there 99% of the time to make up for not having a good enough intercooler.
RW
RW
Originally Posted by EIL132
Quite a trick one
