battery light issue UPDATE SORTED
Old Jan 11, 2006 | 02:29 PM
cossiecrew's Avatar
cossiecrew
Default battery light issue UPDATE SORTED
right about 2 weeks ago on this escort gti were working on the battery light kept coming on and off then stayed on for 2 days and the car died cut out dead so had alternator reconned and recharged battery built it all back up starts 1st turn of the key but battery lights staying on permanent any ideas
Old Jan 11, 2006 | 02:34 PM
EssexBoyRacer's Avatar
EssexBoyRacer
alternator not charging.
Old Jan 11, 2006 | 02:35 PM
EssexBoyRacer
sorry just saw you've tried getting it reconned. May still be faulty. My m8 replaced his alternator 3 times before he got a working one!
Old Jan 11, 2006 | 02:36 PM
cossiecrew's Avatar
cossiecrew
so you think the alternators fuct i just got it back today from being reconned as thats what i would say it was the alternator seems to be whinning alot aswell do you reckon they fucked the job up
Old Jan 11, 2006 | 02:37 PM
CarismaDave's Avatar
CarismaDave
Brake fluid level dropping below minimum? Had this in my FRST once. May not be but worth checking
Dave
Old Jan 11, 2006 | 02:46 PM
cossiecrew's Avatar
cossiecrew
Old Jan 11, 2006 | 02:59 PM
EssexBoyRacer
brake fluid?
If its whining make sure the belt is tight enough.
The battery light comes on when there is no live feed (or at least below a certain amount) from the blue wire (I think) off the alternator. No live feed - no charge. So it really can only be the alternator or its associated wiring at fault.
Old Jan 11, 2006 | 03:05 PM
CarismaDave
sorry, didn't read the entire post just the heading! Teach me not to skim read!
Old Jan 11, 2006 | 03:12 PM
Robsta35's Avatar
Robsta35
Check the wiring going into the alternator if thats ok then it could be a diode in the alternator even though you have had a new one it could still be faulty
Old Jan 11, 2006 | 03:14 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Had a fuse blow once and the warning light came on and it wasn't charging. Changed the fuse and all okay again. Worth checking all the fuses.
Old Jan 11, 2006 | 03:37 PM
andre_k's Avatar
andre_k
Dave
handbrake/abs light
Old Jan 11, 2006 | 03:41 PM
cossiecrew's Avatar
cossiecrew
update checked all fuses and riddled blue wire on alternator still the same ive got to drive it to the place in the morning but surely it shouldnt whine anyway? surely its fucked as ive never had a recon whine ?????
Old Jan 11, 2006 | 04:35 PM
CRABBY's Avatar
CRABBY
i had the same problem once on a sierra i had changed the alternator,battery etc and the battery light was still on
i then called out an auto electrician out and he suggested i take the cowling off from around the steering wheel and where the wiring runs down from the ignition it goes down to a connector plug which sometimes can have a crap connection over time.
he then told me to cut the wires off from both sides of the plug and reconect them using a new connection box and it worked a treat.
I dont know if its the same on the escort and i wouldnt cut the wires before having someone who knows look at it but it might be worth taking the cowling off and see if the wires run down to a connection plug and give them a wiggle see if it makes a difference hope this helps
Old Jan 11, 2006 | 05:26 PM
Exeter J's Avatar
Exeter J
I've had this problem before a few times,
both times it was the Earthing cable to earth the engine to the body of the car either not very well connected/rusting or actually broken.
Old Jan 11, 2006 | 09:17 PM
cossiecrew's Avatar
cossiecrew
cheers guys ill check it out tommorow
Old Jan 11, 2006 | 09:30 PM
rsrob's Avatar
rsrob
blue wire on the alternator
check it isnt broke in the middle somwhere, if it is the bat light will stay on and cause it not to charge
Old Jan 12, 2006 | 12:42 PM
cossiecrew's Avatar
cossiecrew
cheers to everyone that tryed to help us out we took the car there this morning and the guy listened to it and agreed the alternator was fooked so i took it home removed it off the car and took it back he put it on his machine and it worked mint so he rang his auto electrics mate and he said he thinks its the fuse box so luckily i had a spare 1 here so strip down and rebuild light had gone out so i went down the street and the light was back so after ages of pissing about we finaly found it was the blue wire but was so hard to find and weve had to strip loads of shit off just to be able to see it the lad had the clutch done recently so we reckon they must have trapped the fooker heres a pic
Old Jan 12, 2006 | 12:43 PM
cossiecrew's Avatar
cossiecrew
van_dogg_pavvy
Mar 3, 2016 09:30 AM
jaysoc1
Aug 20, 2015 08:18 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
xr_craig
Aug 7, 2015 06:00 PM
