PC Techs help !! Wireless question..
Old Jan 10, 2006 | 03:19 PM
AndyBlackFRST's Avatar
AndyBlackFRST
Default PC Techs help !! Wireless question..
Had a few issues with setting up a Wireless router up for a guy at work.
The setup we have is..
Linksys Router
BT Broadband line
Laptop with built in wireless
We have tried with 2 routers, both LinkSys
1 - If we power on the router and the laptop, the laptop sees the wireless network, but if we connect the router to the internet, the router restarts continiously.
2nd router - This when connected to the internet is fine, but will not issue an IP addy to the laptop.
The laptop works fine running through the router using RJ45.
Andy ideas?
Old Jan 10, 2006 | 03:22 PM
Spiky's Avatar
Spiky
Default Re: PC Techs help !! Wireless question..
Linksys Router
BT Broadband line
Andy ideas?
first router fooked then
2nd,
have you enter SAME ssid in both laptop and router?
start off with NO security or encription
make sure router has had DHCP enabled
Old Jan 10, 2006 | 03:33 PM
AndyBlackFRST
Have the config sheets here and DHCP is enabled..
Will check SSID now
Old Jan 11, 2006 | 08:43 AM
Jonzy's Avatar
Jonzy
Disable QOS in the network setup of the clients, then reflash the routers with the latest firmware.... even if its the same as already on there.
QOS is a total cnut with wireless and dhcp
Old Jan 11, 2006 | 08:54 AM
DanRSturbo's Avatar
DanRSturbo
Ok, so you have a main pc which has bt broadband installed on and a laptop you want to connect it to ?
And the bt modem is now plugged into the router ? And there's RJ45 csable going from one of the free ports into the network card in the main pc.
If the IP address is assigned automatically from BT, then nothing should change at all. If it has to specifiy an IP address then you will need to tell the router this. The only time you need to setup the SSID is when you setup the wireless network.
Old Jan 11, 2006 | 10:16 AM
Check wireless is actually enabled on the second router
Sounds stupid but I've had this before on wireless routers straight out of the box. Would explain why it works on RJ45 connection.
Old Jan 11, 2006 | 10:51 AM
EssexBoyRacer's Avatar
EssexBoyRacer
Check you have the latest firmware on the router.
I've had to update the firmwire on 2 USR routers / access points in the past before I could get them to realiably connect.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
