COSWORTH RAD QUESTION
08-01-2006 | 03:03 PM
Do all cossies use same rad,ie 2wd ,4x4 and escos,just woundering
cheeRS stu
08-01-2006 | 03:04 PM
08-01-2006 | 03:06 PM
DAMO whats the diffrence,just i have a near new rad out of a 4x4 saff,and a guy was woundering if it would go in his escos
cheeRS stu
08-01-2006 | 03:11 PM
08-01-2006 | 03:16 PM
So damo it seems they are physicaly the same size
cheeRS stu
08-01-2006 | 03:18 PM
should be yes
08-01-2006 | 08:51 PM
yes ... you can use a 2wd in a 4wd i have done it
08-01-2006 | 08:54 PM
same as ive used it aswell
basically all you got to do is fit that l shape water pipe and drill a hole for a clip to hold the fans in
mounting brackets are different spacing between models where the rad bolts to the intercooler but with slight mods they all fit each other
markk
02-12-2021 07:59 PM
big_Rad
15-09-2017 10:36 AM
Anutternutter
24
31-08-2015 02:24 PM
cossie4x4
14-08-2015 07:29 PM
14-08-2015 08:29 AM
