Does T-3 cossie turbo need water cooling???
Does a sapph 2wd stage 1 really need watercooling on the standard T-3 turbo.
The car is used daily and 2 or 3 times a year he goes to the ring and some burn-outs
Not my car by the way.
Cheers Ruud
Cheers Ruud
Well Rene there is a problem.
It's for my brothers car, i just placed a new turbo on his a car and now it's leaking water on the back of the turbo.
And on thuesday i'm off for holiday, and if i can't get i sorted then i plug the watercooling off and then drive the car to JPcars, that's why i asked it
Cheers Ruud
Cheers Ruud
not a case of it being hp related, its a case of using the correct cooling for the type of bearing housing that the turbo uses.
the ones designed for no water cooling have increased capacity oil galleries to compensate
id say it will be fine to temporarily run it water free until its fixed properly
I didn't run water on my T3 for three years - it was fine.
I don't run water on my T34 (18 months) - still fine.
Yeah but 18 months sat in the boot doesn't really count
i agree with richard first thing i ever do is take the water off, it was only ever put there to make the heaters get hot quicker, just make sure you leave it idling for a couple of minutes (as you should do anyway) before switching off. cheers nomad
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
19-08-2015 06:25 PM
