bottom end balancing
Old Dec 30, 2005 | 01:42 PM
M K's Avatar
M K
Default bottom end balancing
bought a second hand 1.6 cvh bottom end consising of,,
forged pistons
steel rods
l & b crank etc,,,,
will be running full cosworth p8 management on greens/3 bar/ t34 .68 etc
ive had it looked over & been given a clean bill of health but the engine did not come with flywheel or clutch,,,,i have got a new 4 paddle clutch & had a standard rs turbo flywheel skimmed ready to go on
but should i pull out the crank/rods/pistons & put on the new flywheel & clutch & have it all balanced as 1 before the head goes on
or do you think it will not make much difference???
i copied prices from SPECIALISED ENGINES IN GRAYS to give me a rough idea & its only around £77 to do it all
Engine Balancing :
All static and Dynamic Balancing is carried out on the premises. While-U-Wait service for 4-Cylinder Engines. For all V-type engine balancing, we require one complete piston con rod, bearing set, damper, flywheel, clutch and all relevant bolts.
(1)Half balance - 4 pistons and rods (top end): £38.50
Half balance - 6 pistons and rods (top end): £58.00
Half balance - 8 pistons and rods (top end): £72.00
(2)Half balance - 4 cylinder crank, flywheel, clutch, damper and all necessary nuts and bolts. (bottom end): £38.50
(3)Full balance : As 1 and 2 above - 4 cylinder : £77.00
opinions please
i reckon for around £77 its rude not to
cheers
marc
Old Dec 30, 2005 | 01:53 PM
M K's Avatar
M K
also what other firms in essex can do this???
phoned burtons but they want over £180
Old Dec 30, 2005 | 03:03 PM
M K's Avatar
M K
Old Dec 30, 2005 | 08:44 PM
M K's Avatar
M K
NO 1?
Old Dec 30, 2005 | 09:50 PM
scruffythefirst's Avatar
scruffythefirst
Worth getting it done, no idea if specialized are any good.
Burtons have a good rep, but just send all their work to the engineering shop next door.
Old Dec 30, 2005 | 09:54 PM
Oranoco's Avatar
Oranoco
Had mine done when I blew the fooker to pieces. Wasn't expensive in the grand scheme of what I killed so thought why not.
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
