saff cosworth is it heavyer than a escort cosworth
Originally Posted by bluescortcossie
2wd is the lightest
the escort cos is a fat little thing at about 1800 kg
2wd sapp about about 1500 kg i think
2wd is the lightest
I thought Esc Cos was about 1260kg and Sapph 2wd about 1220kg
2wd is the lightest
Would be useful to know though.
Autocar kerb weights in their tests
Escort Cossie '94 1275kg
Sapphire Cossie 2wd 1206kg ( test weight 1388kg )
E36 M3 1520kg
E36 M3 Evo 1471kg
E36 M3 Evo SMG box 1510kg
Impreza Turbo ( Classic ) 1235kg
R33 Skyline 1601kg
Lancer Evo 5 GSR 1433kg
E36 M3 1520kg
E36 M3 Evo 1471kg
R33 Skyline 1601kg
Sapph 4 x 4 http://www.rsownersclub.co.uk/car_info/ser4x4sc.htm - 1,280 kg (2,816 lb), add 10 kg (22.05 lb) for Cat model.
Sapph 2wd http://www.rsownersclub.co.uk/car_info/Ser2wdsc.htm - 1,250kg
Esc Cos http://www.rsownersclub.co.uk/car_info/esccos.htm [doesn't give kerb weight tho]
Caraholic
Depends on what Escort and what mods are fitted to it .
A late model EECIV with aircon is the heaviest (side impact bars, twin airbags etc).
My car's wet weight with fuel is 1419kg. However, I can get this down to 1385Kg by removing MDF shelf, spare wheel and tool kit.
Larger than standard wheels and brakes add a significant amount of weight.
My Sapphire weighed 1275Kg with spare wheel removed and half tank of fuel.
None of these weights include driver.
my old ANZ CAR was 1130 kilos wet without driver inc some fuel
but my new merc is 980 kilos wet
four wheel drive is the most and if you start adding bits like big diffs ect an escort will see 1400 kilos
Originally Posted by Fast Guy
Wow, There was Escos in Best MMotoring, wonder which episode can that be, maybe avalible somewhere on the net...
jessie_rs
11
03-06-2019 04:57 PM
