Series 2 help
Series 2 help
Im about to help a friend take off his standard s2 gearbox with abs and replace it with a box without the abs. Could someone tell me exactly what i have to do to bin the abs and the easyest way to do so.
The belts snapped ages ago how do you meen buy block them off ? could someone explain in a bit more detail im a bit slow lol
It Wasnt Me!
why a new gearbox, maybe im missing something but arent the belts connected to teh drive shafts. . and even with the abs removed the abs driveshafts are fine to keep!?
if you just remove the belts thats still not good enough as the fluid is still having to be pushed through the system sso would be a waste of time
buy an xr3i res as it dont have the two extra feeds or you can block the pipes with bolts and jubilee clips, and when you have binned the abs units you can either bend and make a new pipe to connect the pipes up together under the car or make new ones from the master cylinder.
why a new gearbox, maybe im missing something but arent the belts connected to the drive shafts. . and even with the abs removed the abs driveshafts are fine to keep!?
Hey peeps thanks for the reaplys ! The gearbox is knackered and we thought that putting the new box on (not from an s2) we would have to bin all that abs rubbish ?
if u aint sure what ur doin why dont u just pay sum1 who does and then u aint guna have the wonder if uve done it right.!!!
if u want it doin i work at JAMSPORT we will do u a good deal.......
all the pipes are bolted to the back of the gearbox cradle...
you need to run new pipes from the master cylinder to the T pieces on both wings, dump the pumps and pipes bolted to the gearbox and back of the cradle, block the 2 pipes coming from the reserviour, bleed the system and your done
muz
30-09-2015 08:29 AM
SMILER258
28-09-2015 09:04 AM
