saph rev counter help please
ok coming back from stratford yesterday and 3rd gear, boot it and the rev counter goes off the scale (and stays there) while the engine feels like its hesitating and juddering etc,
cruising in 5th gear the rev counter is going all over the place rapidly
anyone else had this ??
heeeeeeeeeeeelp
heeeeeeeeeeeelp
how the hell do i check them and where are they on the car ???
i know where the phase sensor is but isnt it inside the dizzy ?
fookin cars lol
it wont damage anything while its doing this is it as i havent got time now to check them but ive got to go to leeds tonight and back tommorow before its put away for xmas
cheers gracie
matt
fookin cars lol
cheers gracie
matt
PassionFords Creator
Dont bother, cut out the connectors on teh firewall instead and solder all connections. Will likely fix the other niggles you have had teh last few months too. Job Done.
Worst case scenario, unplug and replug all three a few times.
DO NOT SPRAY WITH WD40 OR SIMILAR GARBAGE.
cheers stu
im far from the best at soldering and hate messing with 15 year old car wiring so i may just try unplugging them all a good few times
if it continues then i will have no choice but to try soldering it
thanks stu and gracie for helping me
Team HOTHOT!
Matt - if you don't fancy soldering the wires yourself, then come upto mine one weekend and i'll do it for you i've got all the equipment here so its not a problem
Super Moderator
must admidt the thought of sitting on the engine soldering wires really does not thrill me one bit .. must do mine tho
Originally Posted by slowpoke
youre far too good to me gracie
matt
matt
i still feel bad about them wheels tho matt
matt
When i first had mine, it would sometimes idle a bit high (Nearly on the limiter!! ) and the tacho used to be irratec
My mate said to try the three plugs, cut & soldered them Job done!!
Team HOTHOT!
Originally Posted by Jim Galbally
guzzler, isn;'t that the whole point?
yes Jim - but when it conducts accross all the connections and terminals then it becomes a bad thing
Team HOTHOT!
its the 3 plugs on the bulkhead above the camcover - they unplug and seperate the engine loom from the car loom, remove these plugs and replace with wire and you eliminate the electrical gremlins that they cause
Originally Posted by abdr500
how come i only got 1 conector on my cossy its the reverse switch plug above the cam cover
but sayin that its not so good cos they cause so much problems lol
i know where they are gracie im scared of touchin the feckin things pmsl
ho ho ho merry christmas pmsl
matt
Russ Payne
25-09-2015 08:29 PM
