What will a T28 flow?
Old Dec 18, 2005 | 06:41 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Default What will a T28 flow?
Just wondering what bhp a T28 would flow and at what point it boosts on a cossie engine?
Sorry - small argument to settle with a mate
Old Dec 18, 2005 | 07:32 PM
DOO's Avatar
DOO
my T28 holds 22 psi and is 300BHP
Old Dec 18, 2005 | 07:34 PM
Big Will_'s Avatar
Big Will_
You don't know if the T28 will flow any more than that do you?
I take it you've had 360 thrust bearing etc. put into that?
What point in the rev range does it boost at?
Will
Old Dec 18, 2005 | 07:36 PM
DOO's Avatar
DOO
yep 360 bearing boost starts at around 1600/1700 rpm
Old Dec 18, 2005 | 07:37 PM
DOO's Avatar
DOO
TBH i don`t think you get much more than 300bhp
Big Will_'s Avatar
Big Will_
Sweet
Just that i'm setting my 2.0 Zetec Turbo up for 0-60's and sprints - want to make about 300 (give or take a bit) - but basically want drivability and as little lag as possible
My mate was trying to argue that a T28 wouldn't flow more than 260bhp even as a 'stage 3'
Old Dec 18, 2005 | 07:39 PM
markk's Avatar
markk
i used to run my T28 ( was a hybrid type) at 30psi, just the cores didnt last very long as the actual thrust is very small
Old Dec 18, 2005 | 07:40 PM
Big Will_'s Avatar
Big Will_
Am i right in thinking the GT28 turbo's are roller bearing versions of the above?
Aren't roller bearings meant to reduce lag?
Old Dec 18, 2005 | 07:41 PM
DOO's Avatar
DOO
had mine rollers at 296bhp that was just a shoot out day and mine needs setting up so should see just over 300BHP when set up correctly
Old Dec 18, 2005 | 07:42 PM
rsnissan's Avatar
rsnissan
jap s13 turbo is good for 280bhp, s14/15 is good for 300 pulsar T28 is good for 330 at best.
The exhaust housing and wheel on the pulsar is different, the compressor housing is smaller on the pulsar one as well
s14/15 compressor housing on the pulsar turbo = 330bhp
would be on limit though.
Old Dec 18, 2005 | 07:46 PM
Big Will_'s Avatar
Big Will_
So if i managed to get hold of a Jap turbo - and ran it at 300 - would i be looking at decent life or not?
Basically i don't want to constantly pour money into this - i'm happy to do it once and look after it
Old Dec 18, 2005 | 07:58 PM
rsnissan's Avatar
rsnissan
i would think 300 would be fine on a the pulsar turbo as it is...............if you wanted more than you can change the comp housing like i said.
Just get hold of a pulsar t28 and get it rebuilt and away you go.
Old Dec 18, 2005 | 08:04 PM
markk's Avatar
markk
i had an S14 comp housing and wheel on a small escort cos rear housing, i would recommend a 360 thrust or it will eat itself on a regular basis if your running sort of + 20psi regularly - mine did - hence why i changed turbos to get the bigger core bearings and thrust
Old Dec 18, 2005 | 08:13 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
T28 is as vague as T3, T4, etc etc, you see T28s that can flow no more 270odd, but others (GT2871R) that are good for 400bhp, but still technically a T28.
So question is, what T28?
BTW, S13 turbos are all T25s, not T28s
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
bigdel
Sep 22, 2015 05:50 PM
