S2 front and rear brake disk setups please
you can do cossie front and rear conversions but cant rmember the combinations for front and rear i think fronts were 4wd calipers and 2wd disks. tell me if im wrong
the rears was xr4i rear disks or summing
if you are using std size cossie fronts, then go for non-cossie mainstrem/XR rears, they are a bit smaller (and cheaper ) and the brake balance is better. You will need suitable caliper brackets to suit the smaller discs though.
just finding my feet
dont supose you know a man that does em do ya
then tell him the price as your braket kits are good quality adn come with the correct bolts that dont cause the hub to rub on the bolts
the brakets i got i had to fooking grind the edges off THEN i seen your brakets
when your on about non cossie mainstream or xr.
what models are we on about are they soldi or vented cheers
ALL other Sierra/Sapphire rear discs are solid 253mm diameter, that includes 2.0i Sierra, GLS Sapphire, XR4i/XR4x4 models as some examples. ALL solid-disc variant calipers are the same, including Granada. (careful with Granada discs, many are 5-stud so no use to you)
I have 253mm non vented discs off a bog standard Sierra, with my set-up thats more than enough braking for the back end, and even then with the bias valve the pressure to them is reduced.
I just need them to work, not to look bling or big and fancy etc.
Oh and the brackets came from richm
Originally Posted by Damo V
st170????
st170????
i would love rs ones
st170????
Or are they too expensive that way
Brackets from Richm are top quality
Have a set here that I never did get round to fitting as I bought another car but might throw them onto the S2 thats sitting in my garage
Originally Posted by david
Fook that, can be done for under Ł200 and thats with new disks and pads etc
People are starting to rate the new Carbon Redstuff on other perf. car forums - apparently EBC has taken control of all production these days, and quality has improved.
I'd recommend National discs - really good quality for the price!
track.focus'd
12-08-2015 05:53 PM
