Fuel level sender - Help required
Old Dec 16, 2005 | 07:46 PM
Sean Bicknell's Avatar
Sean Bicknell
Default Fuel level sender - Help required
Hi Guys & Gals,
I have fitted a bag tank to my car and it doesn't come as standard with a fuel level sender. I am looking to fit one, bit I don't have too much space.
The bag tank is foam filled so I can't use a "float" type sender. I need one of the tube type ones, like the ATL one. However the mounting plate of the ATL sender is slightly to large.
Does anyone know of any other fuel level sender systems out there???
Thanks
Sean..
Old Dec 16, 2005 | 10:30 PM
Cam's Avatar
Cam
Default Re: Fuel level sender - Help required
Originally Posted by Sean Bicknell
Hi Guys & Gals,
Thanks
Sean..
The Fuel Safe sender is pretty compact
http://www.fuelsafe.com/parts.htm
http://www.fuelsafe.com/pdf/Parts_&_Acces.pdf
Old Dec 16, 2005 | 10:42 PM
Stu.H's Avatar
Stu.H
just keep it topped up at all times you pikey
Old Dec 16, 2005 | 10:47 PM
RichardPON's Avatar
RichardPON
Mine runs a float type ATL job.
Haven't seen any others about.........
Get some pics up of the car sharpish though
Old Dec 16, 2005 | 10:48 PM
Sean Bicknell
Cheers Cam!! That does look good. I have sent them an e-mail regarding the measurements I need to make sure I can make it fit.
Stu, Piss Off!!!!!!!!!!!!!!!
Old Dec 16, 2005 | 10:49 PM
Stu.H's Avatar
Stu.H
Old Dec 16, 2005 | 10:52 PM
Sean Bicknell
Yeas mate I have looked at the ATL one and the diameter of the piece that sits outside the tank, is slightly to large to fit where I need it to go. Fingers crossed the one Cam has pointed out is a bit smaller.
The cars getting there mate. I am rewiring it at the moment. Will be out at Bedford in Feb.
Sean..
Old Dec 17, 2005 | 01:07 PM
Spiky's Avatar
Spiky
Sean..
pleeeeeeeeeeeeeeeeease can i have a ride in the car?
Old Dec 17, 2005 | 03:51 PM
Sean Bicknell
Course you can you plank!!
You on track with yours???
Us Lotus boys will show these "Brute force and ignorance" cossie mob a thing or two!!!!
Old Dec 17, 2005 | 04:42 PM
NUTS RuS's Avatar
NUTS RuS
http://www.centroidproducts.com/
Old Dec 17, 2005 | 05:55 PM
Spiky's Avatar
Spiky
yeah man i'm all booked up for bedford, should be fun
Old Dec 17, 2005 | 07:52 PM
marco polo's Avatar
marco polo
Bring it on
Old Dec 17, 2005 | 07:53 PM
Sean Bicknell
Cheers matey.
I have had another look at everything today and I think I am going to change the plate on the tank around a bit to make space for the ATL sender. On closer investigation it seems like the ATL, cams link and your link all use the same tank sender, so with a bit of jiggery pokery I should be able to make it work.
Sean..
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Dubs44
Sep 19, 2015 06:31 AM
CrOwSoN15
Sep 10, 2015 07:33 PM
