cosworth relays
cosworth relays
On the engine loom of a cossie there are 2 relays near to the ecu.
is there anything special about them? or are they normal 3 pin relays?
I have a loom but no relays and don't fancy paying cossie tax if they are nowt special.
A 3 pin relay would be a flasher relay!!!!????
The 2 near the ECU are 40 amp relays for the ECU ignition feed, in jector feed and the other is fuel pump, amal valve and idle speed control valve...
Not sure on the pin configuration but it is possible that they are Ford unique but not Cossie unique.....(Ford just changed the pin configurations round over a standard relay)
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
