can someone help with an ecu problem????????
Old Dec 16, 2005 | 08:26 AM
iggy gt4's Avatar
iggy gt4
Default can someone help with an ecu problem????????
i took my cossie nto get the fueling sorted out the other day,it was running a bit week,so the tuner started to adjust the mixture with the screw that is on the ecu,but nothing happened the level didnt change...........
he tried for a while,but still nothing happened,so he told me the little bit of metal might have come off that connects the screw to the board,so when i got home i took the top off and had a look but it was still there?????????
but i have now been told that my car might be the change over year and the screw might not do any thing anyway,as the car might have an oxygen sensor????????there is nothing in the exhaust,the only other thing is the one at the turbo.....
can someone shed some light on this for me????the car is a 1992 k reg 4x4,i need to get the fueling done as it is costing me a fourtune at the min......
cheeRS ivan.......
Old Dec 16, 2005 | 08:28 AM
Stu @ M Developments's Avatar
PassionFords Creator
Its lambda controlled pal, and can still be adjusted by the ecu but you need the original marelli software to adjust it.
Sounds like the chap wasnt too familiar with the Cosworth marelli system, try someone who specialises in them.
Old Dec 16, 2005 | 08:35 AM
Disabled Account's Avatar
Disabled Account
Stu, I thought the ECU screw is for adjusting idle mixture only.....or have I got that wrong
Old Dec 16, 2005 | 08:43 AM
Correct.
Old Dec 16, 2005 | 08:48 AM
Disabled Account
Sorry Stu I know that you are busy.....BUT do you mean:
a. CORRECT = I HAVE got that wrong.
Or:
b. CORRECT = ECU screw is for adjusting idle mixture only.
Old Dec 16, 2005 | 08:51 AM
Or:
Correct, you got it wrong Dougie
The Screw on the ecu is whats known as a "Global Modifier" It adds a percentage to the fuel map.
Old Dec 16, 2005 | 08:53 AM
Disabled Account
Sorted!
Old Dec 16, 2005 | 08:54 AM
SPADGE's Avatar
SPADGE
Not uncommon for the mixture adjustment pot on the ecu to die!
Try another ecu
Old Dec 16, 2005 | 12:41 PM
iggy gt4's Avatar
iggy gt4
cheers so i need it set up by you then stu??????????
when can i come up???????????
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
tib2220
Sep 14, 2015 12:33 PM
dms04
Sep 11, 2015 01:57 PM
