Actuator Preload
Old Jul 13, 2004 | 10:21 AM
JohnXr's Avatar
JohnXr
Default Actuator Preload
if the actuator preload is set to 8lbs, what psi would it be running
its only that i got the new turbo on the car and he said its set to 8lb preload,
but its only running 8-10 psi, im sure he said at the place it was set so it would be running around the 18 - 20 mark
any ideas
Old Jul 13, 2004 | 10:25 AM
Stu @ M Developments's Avatar
PassionFords Creator
8lb preload means that gate starts to move at 8psi.
This will give you a maximum engine pressure of 8psi and then only if you have an intercooler and intake system with ZERO pressure drop.
The missing component from the equasion is boost control.. does this system use it?
Old Jul 13, 2004 | 10:34 AM
JohnXr's Avatar
JohnXr
its on a bleed valve as we had to by pass the amal valve when we had the last actuator on there as the minimum it would run was 15 psi and then if the amal valve was connected it would double it to 30 psi, so we by passed the amal valve and run a bleed valve but now we have a -31 actuator should we reconnect the amal valve ?
Old Jul 13, 2004 | 10:38 AM
CabrioTurbo's Avatar
CabrioTurbo
it will run 8psi on actuator only pressure... with a bleed valve you should be able to make it run a lot more! or even with the amal valve connected it 'should' give arround 14-16Psi
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
