Heater Matrix - Removal/install - HELP!!!!!!!!!!!!!!!!!!!!!!
Old Dec 10, 2005 | 01:07 PM
DanS's Avatar
DanS
Default Heater Matrix - Removal/install - HELP!!!!!!!!!!!!!!!!!!!!!!
Ok I've been putting this job off for 3 years as i've been told its a pig of a job..... but after succesfully installing an altornator this morning i was on a roll!!
Can someone please explain a) what the feck this thing is and b) how do i remove it to get to the heater matrix
Pictures taken from divers side foot well, just behind the stereo!
Inlet and outlet water pipes i guess?
Lots of black plastic, how do remove this???
I can only find one bolt at the very top, but i'm sure thats not the only thing holding it in place
HELP!!!!!!!!!
Old Dec 10, 2005 | 01:32 PM
BillyCabrio's Avatar
BillyCabrio
Dash out job, makes it a whole lot easier.
The whole heater box comes out in one go once you removed the pipes, nuts etc.... from the engine bay side.
Good luck
Old Dec 10, 2005 | 01:34 PM
DanRSturbo's Avatar
DanRSturbo
Good luck
You wanna do mine ?
Old Dec 10, 2005 | 01:36 PM
DanS's Avatar
DanS
noooooooooo not what i wanted to hear
Took me ages to get the dash half way out last time i tried
Old Dec 10, 2005 | 01:37 PM
BillyCabrio
If ya like
But i'll have a 24 pack of Smifnoff Ice Red
Old Dec 10, 2005 | 01:38 PM
BillyCabrio
Once you've done it once, getting the dash out again is the easy job
Old Dec 10, 2005 | 02:20 PM
DanRSturbo's Avatar
DanRSturbo
If ya like
But i'll have a 24 pack of Smifnoff Ice Red and you can take Anna shopping whilst I do it
Sounds fair
Old Dec 10, 2005 | 02:28 PM
DanS's Avatar
DanS
Sounds like the dash it coming out next weekend then
Old Dec 10, 2005 | 02:57 PM
AndyRST's Avatar
AndyRST
Im sure i managed to undo a few bits of the heater controls and then with the heater pipes removed and clamped in the engine bay, i managed to wiggle the matrix out via the drivers footwell
Old Dec 10, 2005 | 03:01 PM
Jim Galbally's Avatar
Jim Galbally
think yourself lucky you dont have a sierra then dan!
Old Dec 10, 2005 | 03:21 PM
AndyRST's Avatar
AndyRST
yeah Serria's are just piles of shit with a half decent Cosworth engine in them
Old Dec 10, 2005 | 03:50 PM
DanS's Avatar
DanS
hmm anymore detail mate? is it possible to remove just the center section (ie stereo and bit above the glove compartment) from the dash? I've started removing bits from the dash now anyway so looks like i'll just gradualy take the whole thing out..........
Old Dec 10, 2005 | 04:02 PM
Ian3dr's Avatar
Ian3dr
No need to take the dash out mate.
All you need remove is the centre console.
Undo the water pipes in the engine bay, and under the dash each side there are 2 13mm bolts. These hold the entire heater assembly up. wiggle the heater down and the matrix will slide out drivers side.
As Haynes says, rfitting is the reversal!
40 mins max
Old Dec 10, 2005 | 04:04 PM
DanS's Avatar
DanS
Cheers Ian,
Haynes doesn't mention anything other than actuly fitting the matrix i.e. nothing about the dash etc.
I take it those yellow pipes are the "top" of the matrix, just undo those screwns (and hoses in engine bay) and in theory it just slides out from there? What about those struts shown in the pics, do i need to take those off?
Cheers,
Dan
Old Dec 10, 2005 | 04:18 PM
AndyRST's Avatar
AndyRST
Yeah as Ian said you removed the centre consol (think i just un screwed mine and moved it far enough out the way) and then you can get at the matrix to slide out from its housing towards drivers foot well.
Old Dec 10, 2005 | 04:36 PM
Ian3dr's Avatar
Ian3dr
Yes the 2 'yellow' pipes are the top of the matrix, and are these are what the water pipes in the engine bay are connected to.
From memory (it was about 3 yrs ago I did one), 2 x 13mm bolts, the whole heater will be loose for you to wiggle the heater box down (its massive!) and the matrix will slide out! There are also some cables that contol the direction flap on the passengr side of the heater that will need disconnecting as well (1 self tapper)
Old Dec 10, 2005 | 04:41 PM
rssapphowner's Avatar
rssapphowner
you dont have to take the dash out but you need to lower the heater box down on one side, i did mine on my series 1 took me a while but got it done good luck
Old Dec 10, 2005 | 04:42 PM
Damo V's Avatar
Damo V
Ian and andy are corrrect
before you undo the 13mm bolts, and once you have removed the pipes in engine bay, undo the 2 self taping screws holding the metal plate to bulkhead in engine bay
you will only need to remove centre console, you WILL need to remove those little strips of metal you mentioned once its wiggleable lol, you may be able to just about get the pipes out the bulkhead, if you can there is no need to remove the cables then just undo the 2 self tappers on the plastic matrix to slide it out the box, remove all the old leaves in there too
Old Dec 10, 2005 | 04:47 PM
AndyRST's Avatar
AndyRST
Yeah whats all that about leaves in there, i found half a tree in mine when i did it back in 1998 (How old am i feeling now)
Old Dec 10, 2005 | 04:49 PM
Damo V's Avatar
Damo V
well I did mine in 1996/7
Old Dec 10, 2005 | 04:50 PM
AndyRST's Avatar
AndyRST
You is also old then
Old Dec 10, 2005 | 04:53 PM
DanS's Avatar
DanS
Thanks guys!!
You say theres two 13mm bolts, i can only see one from the drivers footwell, is the other visable from the passenger footwell?
EDIT
never mind
Old Dec 10, 2005 | 05:50 PM
Wazzzer's Avatar
Wazzzer
Have fun, just done mine
Old Dec 10, 2005 | 06:07 PM
AndyRST's Avatar
AndyRST
and does the heater come up nice and hot now?
Old Dec 10, 2005 | 06:17 PM
Ian3dr's Avatar
Ian3dr
Thanks guys!!
EDIT
never mind
I think the passenger one is the easiest of the 2 to do!
A long reach extension is required!
Old Dec 10, 2005 | 06:18 PM
Ian3dr's Avatar
Ian3dr
Oh and yes half my garden fell out of mine when I did it! lol!
Old Dec 10, 2005 | 06:26 PM
neilm's Avatar
neilm
Originally Posted by Ian3dr
40 mins max
So why did it take you and Ant nearly two hours to do the one on Dawns old car ?
Did you keep stopping to polish things ya Bufty Puff !
Even the bloke at Kempston Radiators reckoned on an hour and a half, his tip was to loosen the 4 big screws that hold the dash so you can move it slightly
My other tip, after doing the one on Dawns new car is to take out the drivers seat, make a much easier job
Old Dec 10, 2005 | 07:16 PM
Ian3dr's Avatar
Ian3dr
Hello neil!
We got the matrix all in and connected and working in that time, but then had to take half of it back out as I had trapped one of the fooking heater cables!
How are you 2 awyway?
Old Dec 10, 2005 | 07:27 PM
neilm's Avatar
neilm
Fine mate... how's you and Deb ? We'll have to catch up sometime mate ! Are you coming to December Beds Meet ?
Old Dec 10, 2005 | 07:38 PM
SteveB's Avatar
SteveB
Yeah gwannnnnnnnn Ian...... 19th December 7.30 onwards
Old Dec 10, 2005 | 07:50 PM
Ian3dr's Avatar
Ian3dr
Hello Steve!
Sorry cant make a weekday night as I still working nights
Deb and I are fine! The cossie has been tucked away since the tax ran out at the end of Aug, and I havent done a thing to it! Not spent a single penny! Infact I had better go and check that it is still there!
Old Dec 10, 2005 | 09:50 PM
Wazzzer's Avatar
Wazzzer
dunno not had it running long enough to find out
my problem was never the heater not being hot enough, it was the puddle of smelly water by my feet that pissed me off
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
