NA to Turbo power graph help.
Hi, asking for a friends coursework, He needs a power graph of a engine that has been turbocharged. a before and after graph would be brilliant.
Thank you in advance.
Pop on migweb and ask for graps for a LET and an XE
As the LET is just an XE with a few bits changed, like lower comp pistons and a set of milder cams.
But still same head and same inlet manifold etc.
Check out the catalogue Ford released for the RS turbo. it had a grpah of the XR3i output overlaid with the RS turbo output, same for torque too. I've got a scan of it somwhere but I'm at work at the mo.
dont suppose u could dig out the scan if possible as my scanner is bust.
Matt Baxter
16-09-2015 08:30 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
