FAO experts!!!!MARTIN HADLAND!!
...can you run a weber fuel pressure reg upside down its on a 4x4 rail so it bolts to the end and will fit properly upside down...you see i need to do this as the bonnet wont shut otherwise
I dont see a problem except the return is having to travel up then down!
Nige yes the original runs it at an angle...i have got a saff 4x4 rail with dash fittings on the intake end and on the fuel return as the reg is a Mountune item adjustable Grp A suspossed so dont want to change it!!
DavidK
27-09-2015 02:55 PM
