changing a saph 4x4 oil pump
going to change the oil pump on the saph,got the pump ready what other parts will i need (gaskets etc) and is there anything special to do when fitting the pump ?
Get on That!
don't forget to replace the pump hex drive while your at it you'll need a new gasket for oil pick pipe to oil pump and when u have it all back together turn the engine over for 20-30 sec with no plugs in and make sure that the oil pump is primed and supplying oil to the engine.
you can do this either with an oil pressure gauge or remove the oil feed to ya turbo and place it in a container and turn engine over till oil comes outta it.
just make sure u connect it back up though
big_Rad
15-09-2017 09:36 AM
ekjim
17-08-2015 08:57 PM
