DBilas Throttle Bodies
Originally Posted by cossiemen
right Chip, it's for me best mates car which is a Opel (Vauxhall) AsconaA 2.0 16V (20XE).
Ive used them on exactly that engine mate
right, basically what i found was:
Loss of power lower down in the rev range, i think this is largely due to the TPS addustments no longer being accurate in the ECU as it flows a different amount of air for the same amount of throttle.
Midrange largely unaffected
top end improved SLIGHTLY
Overall i would say that if you are keeping the standard management and not getting it reprogrammed then its a bad way to spend your money.
If you combine them with a megasquirt though or similar, would be a nice solution, they have many benefits over a "normal" set of bodies such as the ability to run an ISCV and the fact you can still run an airfilter at the front of the car.
Secondhand in this country they go for 500-600 quid, i have a set in stock if he wants them, but as i said, unless changing management too, i wouldnt recomend it.
Whassup
Okay Chip, thanks for the very usefull info mate
will them him about it and let you know if he want any more information about this or if he like to buy them.
many thanks again mate
if someelse have some experiences with them please let us know
mk3ste
17-10-2021 10:09 AM
