Printer help...
Old Dec 2, 2005 | 08:17 AM
andre_k's Avatar
andre_k
Default Printer help...
put new ink cartridges into my canon printer a few weeks back (printer is fairley new).
now shes going all funny on me...
the top bit is meant to be blue, and the bottom is meant to be a darkish green.
every print comes out like this, every pattern + colour is exactly the same
any ideas why?
Old Dec 2, 2005 | 08:41 AM
EssexBoyRacer's Avatar
EssexBoyRacer
under the printers properties there should be an option to perform a head cleaning process. Give that a try. But be warned it does use up ink while doing it.
Old Dec 2, 2005 | 08:52 AM
DanRSturbo's Avatar
DanRSturbo
Was that genuine canon cartridges ?
Old Dec 2, 2005 | 11:32 AM
andre_k's Avatar
andre_k
DanRSturbo
i dont think so...
Old Dec 2, 2005 | 11:33 AM
andre_k's Avatar
andre_k
my dad said a page went in, got chewed up, he pulled it out, and since its been doing it...
Old Dec 2, 2005 | 11:58 AM
JRST's Avatar
JRST
well, to me it looks like you need to check the black cartridge and make sure its not empty either.
Than do a head re-alignment
Finally if that dont work the head is screwed.
Again did you use canon ink or a refill, this is important because if you did and try getting it fixed under warrantee they will know and wont repair it.
I can explain why this happens technical bbut it is boring and long.
All i will say, is canon ink in optimised to a certain thinkness to ensure it flow through the head and the nozzles easily and helps in the cooling of the head. if you use the wrong ink,, the ink does not cool the head enough and the nozzles burn away. If you look at the ink you will see Canon ink is very clean as it is filterised but refill ink is not. This means if you do run this ink in your printer, particles of the ink will get caught in the nozzles blocking them up and making it easier for Canon to find out when you used the ink.
so, if non of the above work you need a new head. phone canon, and they may even swop out the whole printer. depends on the model. Usually takes 48hrs.
There is good refill ink out there but you have to go looking for it and not many people use it because of the cost.
Hope this helps
Jay
Old Dec 2, 2005 | 12:11 PM
andre_k's Avatar
andre_k
SORTED
cleaned the head, + bottom plate thing, all is ok now
Dr. Ickxs
Aug 15, 2015 11:34 AM
bassboy
Aug 5, 2015 08:21 AM
RS-adam
Apr 27, 2005 11:23 PM
skillicky
Mar 29, 2004 09:15 AM
