saph 4x4 problem help me !!!
Old Jul 11, 2004 | 11:45 AM
slowpoke's Avatar
slowpoke
Default saph 4x4 problem help me !!!
yeaterday car took ages to start, normally just a couple of seconds and it fires into life,
today it took even longer and even once it started it didnt really want to keep running
now when i hold the revs you can feel the engine juddering i dont know if its missing or not but you can hear the engine popping too
any ideas of whats suddenly changed ???????
didnt think it was going to start this morning it took that long
help please.............matt
Old Jul 11, 2004 | 11:49 AM
GARETH T's Avatar
GARETH T
does it idle higher?
Old Jul 11, 2004 | 11:52 AM
slowpoke's Avatar
slowpoke
no just idles normal revs if you just touch the throttle and hold so its revving just a bit higher the engine sounds like its missing to feck
could it maybe be plugs or anything ? dont understand tho what could suddenly of happened etc
cheers....................matt
Old Jul 11, 2004 | 11:59 AM
GARETH T's Avatar
GARETH T
could be plugs, but it could also be a million other things
Old Jul 11, 2004 | 12:01 PM
slowpoke's Avatar
slowpoke
shite lol
cheers gareth had a look around the engine theres nothing obvious wrong with it ie no hoses off etc
Old Jul 11, 2004 | 12:03 PM
NUTS RuS's Avatar
NUTS RuS
whip the plugs out and clean them - thats a good start.
fuel pump sound okay ?
Old Jul 11, 2004 | 01:11 PM
slowpoke's Avatar
slowpoke
am letting car cool right down as its just drove back from litherland
will clean plugs and i think fuel pump sounds good ie no funny noises
anyone else ???????? stu ????????????
can see a trip to blackpool coming on here time crisis 3
Old Jul 11, 2004 | 02:13 PM
Alvyn's Avatar
Alvyn
blue temp switch @ back off the head(Passenger side)would be my guess
Old Jul 11, 2004 | 03:12 PM
slowpoke's Avatar
slowpoke
doesnt that affect the idle tho alvyn ?
i know the one youre on about cos i smacked it when changing all the samcos over so maybe it could be that one
cheers guys keep em commin !
Old Jul 11, 2004 | 04:09 PM
gazcos's Avatar
gazcos
Phase sensor ???
Old Jul 11, 2004 | 08:01 PM
slowpoke's Avatar
slowpoke
had new phase sensor, plugs and ford motorspost blue leads last year so surely they should still be good ?
Old Jul 11, 2004 | 08:09 PM
Alvyn's Avatar
Alvyn
[quote="slowpoke"]doesnt that affect the idle tho alvyn ?
on my 3dr it would tick over no probs but as soon as we tried to rev it, it would cough and blutter and back fire changed the coolant switch and it was fine DONT know if yours is the same thou! it could be a host of things really to be honest
Old Jul 11, 2004 | 08:38 PM
buzznwood's Avatar
buzznwood
As you have done the plugs leads then check your electrical connectors to the injectors and any off the wires running off them if they run into the push/clip together black connectors ford use (I can't remember proper term for them) then they can cause problems.
Over the years the pins can corrode and you get poor electrical contact so they start arcing inside making it worse. Everything can seem fine but it only takes you knock them while your doing another job and if the connection is only just making contact then you can make it worse.
I good idea is when the engine is running, is to go around and give all the electical connectors a good tug and a twist if you've got a lose one it should be pretty obvious .
As others have said it could be done to a millions things but with cars this age it is normally down to elctrical connectors / wiring. Old wiring is bad enough old ford wiring even worse .
Old Jul 11, 2004 | 08:53 PM
slowpoke's Avatar
slowpoke
cheers guys will have a good root around tommorow the only thing that i know isnt quite right is that coolant temp sensor because i had "issues" with it last year so thats the first port of call !
cheers..............matt
Old Jul 11, 2004 | 08:55 PM
RichardPON's Avatar
RichardPON
[quote="Alvyn"]
I'm with you on that Alvyn.
EXACT same symptoms as on mine - coolant temp reading -40c on the old SECS monitor.
Changed the sensor - job done.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
slammedorion
15
Nov 1, 2015 07:17 PM
jdsjojo
Aug 30, 2015 07:48 PM
c20tbo
Aug 17, 2015 10:19 PM
