EFI Management
EFI Management
Hi people
I am looking into putting fiesta efi management on my escort turbo i've got the donor car what parts do i need to change and how do i go about it i want to use the fiesta engine but an T3 turbo still what pipes need to be changed? Also how do you wire the fiesta loom into the escort loom.
Any help will be much appreciated.
cheers
cheers
alrighty then....
you need the engine loom, whole engine (as the head is different and the block has the CPS sensor), flywheel, inlet, coil pack and all related bits and bobs, leads, map sensor, ISCV, EDIS module, fuel injection and fuel pump relays (if you want to rig them up instead of the ERST ones)
Might have forgotten something, anyone feel free to add to it...
if you want to use the T3 you'll have to change the oil return pipe in the block, think it just pushes in
www.rsbible.co.uk is the site you want for the wiring
mk3ste
17-10-2021 11:09 AM
deathrider666
28-09-2015 07:12 PM
