Cossy relay problem!!
Old Nov 19, 2005 | 09:48 PM
Cosworth-aka's Avatar
Cosworth-aka
Default Cossy relay problem!!
Got a slight issue with my cossy!!
The relays under the dash behind the glove box, the 2 pink ones on the right hand side are blowing there ajoining fuses, one on the first click of the ignition and one on second click!!!
Does anyone know what the relays are for so i can source the problem!
Old Nov 20, 2005 | 10:51 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
sounds like ign and fuel pump relays. check the wiring at the battery and bulkhead.
Old Nov 20, 2005 | 11:23 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
pink?
U sure?
Where are these relays? Can you take a pic?
If its the Fuel pump and Ignition relay you should have standard Ford Yellow relays in there. Not any type of pink relay.
It could be why you blow fuses?
Regards
Old Nov 20, 2005 | 11:53 AM
Lloyd's Avatar
Lloyd
there are five relays behind the glovebox, 1 ign, 1 fuel pump, and the other 3 are for the abs.so if the car starts and runs its the abs fuses. do your brakes work?
Old Nov 21, 2005 | 07:44 PM
Cosworth-aka
The car runs and drives. i've got no brakes yet as its been off the road for a rebuild and new pad set. there's no fluid in the resivoir yet as the lines are off so its probably gonna be that!!
Does anyone know why the fuse is blowing though, has the pump got a cut off that could be doing this (saftey feature maybe)
Old Nov 21, 2005 | 08:06 PM
xr4x4rs's Avatar
xr4x4rs
i think the pink relays are for your abs
fuel is yellow i think
Old Nov 22, 2005 | 05:58 PM
Cosworth-aka
definitaly to do with the ABS. unplugged the 2 plugs on the side of the pump and it doesn't blow the fuses anymore. so its either siezed the pump?! or its got a cut off or something (hopefully)
Old Nov 22, 2005 | 07:29 PM
Cosworth-aka
15
Oct 7, 2015 03:43 PM
focus2351
Sep 9, 2015 09:33 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
