Engine comparisons
Old Nov 17, 2005 | 10:28 AM
T28 RST's Avatar
T28 RST
Ok then
Default Engine comparisons
Just say we have 2 engines, both have the same:
Ported head
Uprated cam
Vernier
Low compression
Hybrid turbo
2.5" exhaust
GRS cooler
Both are running 16 psi but one is a 1.6 CVH and the other is a 2.0 ZVH.
Would there be a noticable difference in the power outputs of the 2 engines, i know the torque figure will be higher on the bigger engine but would it improve drivabilty or create more wheelspin/torque steer.
Old Nov 17, 2005 | 10:31 AM
Stealth Bomber's Avatar
Stealth Bomber
You're comparing a 1.6 8valve engine with a 2.0 16valve engine...
Old Nov 17, 2005 | 10:34 AM
T28 RST's Avatar
T28 RST
Ok then
Wrong
2.0 ZVH - 8 valve
Old Nov 17, 2005 | 10:36 AM
peteh's Avatar
peteh
ZVH means cvh head doesn't it
Old Nov 17, 2005 | 10:39 AM
T28 RST's Avatar
T28 RST
Ok then
Correct
hopper350
Sep 4, 2015 12:53 AM
