Sapphire Cossie radiator
Old 18-02-2006, 03:54 PM
  #41
Mike1
Mike1's Avatar
[quote="Lambchop
yeah it will and rich should know. The rad in my 2wd was fucked so i replaced with a 2wd rad...turns out thats not what was in the car so they had to mod it to fit with the 4x4 ic [/quote]
Do you know what had to be modded to fit the rad in with the 4x4 i/c - I'm guessing you don't use the normal 2wd ic holes for the 4x4 ic? Radtec say they only do one 2wd rad - is that correct?
Old 18-02-2006, 04:06 PM
  #42
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Do you need a alloy rad ?
I have had no problems with my re-cord standard rad
Cost me about £98.
Steve.
Old 18-02-2006, 04:14 PM
  #43
Mike1
Mike1's Avatar
Cost me about £98.
Steve.
Well I've just bought a nice shiny Radtec one - put it like this if they can put a man on the moon I'll make it fit somehow .... ...
Old 18-02-2006, 04:33 PM
  #44
Mike1
Mike1's Avatar
Originally Posted by 3drstretch
My rad that i'm running on my car which is 2wd but 4wd cooling system.Which meant changing hoses not RAD
If you wanted to fit the 4x4 i/c with a rad like this do you have to cut off the 2 mounting tabs on the top of the rad? They seemto be hitting the bottom of the 4x4 i/c and before I can get the bolts into the mounting holes?
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Fil
30-09-2015 12:08 PM
Quick Reply: Sapphire Cossie radiator
