ICE BLUE INJECTORS ( FLOW ) HOW MUCH MORE THAN GREENS?
Just wondering how much more these flow than greens, i could have a chance of four, im changing from standard yellow ones and have a brand new set of greens, but if the blues flow more then i might do a deal to get them, any help apreciated
cheers
cheers
I`ve only got a t34, im just about finished my rebuild, low comp pistons 7-2-1 cr, rs 500 cooler, breather system, big filter, stainless exhaust, swirl pot, all samco`s, 044 pump, and my head has been buffed up a good bit, just the usual kind of stuff. i would like a reliable 350bhp, so hopefully my turbo holds on which is probably the next thing to change
Well, you could see 370-380ish on the light blues @ 28-30ish psi.
The greens will fuel to about 350-360 on standard fuel pressure so either run the greens flat out with no margin for error or use the light blues
Go for the blues imo
