Actuators....
Old Nov 9, 2005 | 12:24 AM
Default Actuators....
i need to get a new one does it matter what one i put on i have a -31 but someone has just offered me a new -34? can i use that or is that just a no no.
ps its on my S2
cheeRS
Rob
Old Nov 9, 2005 | 12:26 AM
JAMSPORT's Avatar
JAMSPORT
not a problem a -34 will be fine i use them all the time
wt boost do you want to run
Old Nov 9, 2005 | 12:28 AM
its been running 18psi then dropping down to approx 14/15psi
Old Nov 9, 2005 | 12:29 AM
Rhys's Avatar
Rhys
imo use -31
Old Nov 9, 2005 | 12:32 AM
either should be fine if adjusted correctly
Old Nov 9, 2005 | 12:35 AM
cheeRS people
Old Nov 9, 2005 | 12:38 AM
JAMSPORT's Avatar
JAMSPORT
set the boost and then make shure you get it checked on the rollers so that the fueling is right
Old Nov 9, 2005 | 12:39 AM
it was only set up last month at Powers so ill let the boys mess with her again
Old Nov 9, 2005 | 12:55 AM
JAMSPORT's Avatar
JAMSPORT
Old Nov 9, 2005 | 08:07 AM
JesseT's Avatar
JesseT
Not much difference between the two. The -34 will keep a little more boost and with a non-progressive spring it will be a little more snappy.
Old Nov 9, 2005 | 04:10 PM
nice one peeps. gonna go for a -34 and had a chat with Wes today and gonna do a few little mods too
