help!! computer problem
Old Jul 7, 2004 | 10:41 PM
The Youth.'s Avatar
The Youth.
Default help!! computer problem
For some reason tonight my internet access will only last 5 mins then it can't find any pages, if I reboot it's fine for five mins then kaput!!
kazzaa will work all the time tho
A m8 from work has been round tonight installing norton anti virus and generally cleaning up the machine,he knows what he's doing but he has gone home now and I'm stuck!
whats wrong????
regards,
steve
Old Jul 7, 2004 | 10:42 PM
The Youth.'s Avatar
The Youth.
btw I am on NTL broad band
steve
Old Jul 7, 2004 | 10:43 PM
RANJ's Avatar
RANJ
im gettin this message aswell
i think ntl has sum issues with its dns servers
tho sum users are not getting these issues
Old Jul 7, 2004 | 10:51 PM
The Youth.'s Avatar
The Youth.
cheers ranj, I thought we had fooked something up while messing about!!
steve
Old Jul 7, 2004 | 10:52 PM
RANJ's Avatar
RANJ
no probs
Old Jul 9, 2004 | 09:16 PM
The Youth.'s Avatar
The Youth.
NTL have said it isn't a prob at there end, so must be a fault with my setup, anyone have an idea where to start, cos I can only browse for 5 mins then it can't find the server, kazzaa works all the time tho???
I'm getting desperate now cos I can't keep turning the computer off every 5 mins to get it working again.
steve
Old Jul 9, 2004 | 10:14 PM
Billabong's Avatar
Billabong
Are you connected through USB or Ethernet?
Also, what modem, operating system, any routers involved?
Old Jul 9, 2004 | 11:18 PM
Dan B's Avatar
Dan B
Open a command-prompt window (in XP or 2000, Start -> Run -> cmd; in ME or 9x, Start -> Run -> command).
Type in the following command:
ping cache1.ntli.net -t -l 1
That's a lower-case L after the second "-" symbol......that'll leave a continuous ping command running, which should give you line after line starting with "Reply from...". When your webpages stop working, check the command-prompt window, and make sure it still says the same. If it doesn't, and Kazaa is still working fine, then there's a DNS-issue with NTL's servers. Drop me a PM if this is the case, and I'll give you an alternative set to use, and show you how to change them...
Old Jul 10, 2004 | 09:52 PM
The Youth.'s Avatar
The Youth.
bill, windows 98, Terayon modem, no routers that I know of.
hope this helps
steve
Old Jul 10, 2004 | 09:53 PM
The Youth.'s Avatar
The Youth.
sorry m8 to much of a computer numpty to understand all that
I take it I type that in the DOS window ???
cheers for all the help
steve
Old Jul 10, 2004 | 10:05 PM
whilee's Avatar
whilee
founder of chicken porn
try getting SPY BOT as a back up you might have a virus thats moving about
Old Jul 10, 2004 | 10:09 PM
The Youth.'s Avatar
The Youth.
I had spybot but it stopped working a few days ago, could be connected??
cheers
steve
Old Jul 10, 2004 | 10:25 PM
The Youth.'s Avatar
The Youth.
Just ran spybotit worked ok but found no major probs, had to reboot machine cos my 5 mins were up!!
steve
AJC
Oct 1, 2015 06:47 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
