Turbo timer wiring???????
Whilst empying the track car of all trim bits ive found a cheap fizz turbo timer so may as well wire it in, anyone any idea which wires are for what and were they go?? got RED,BLUE,YELLOW (all quite thick wires) then BLACK and GREY (Thin wires?
BLACK - EARTH
RED - CONNECT TO PERMANENT POSITIVE FROM BACK OF IGNITION SWITCH
Remove wire from ignition switch (Position 2 - I.E normal running position)
and connect the wire removed to YELLOW WIRE.
Connect SMALL grey wire to position 2 ignition switch where original wire was.
Connect BLUE wire to position 1 key switch connection along with existing original car wires.
Hope that helps - Best educated guess for want of better words
If this doesnt work (try swapping YELLOW and BLUE wires)
(You wont damage car or unit if wrong)
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
