high rev gear change from 1st to 2nd - CRUUNCH
When, and only when.. reving high in 1st then changing to 2nd.. it always crunches
any reason why?
box is quaife and has just been rebuilt by bernie.. clutch is a low mileage alcon 6 paddle
any reasons casuing this?
any reason why?
Originally Posted by Kev.H
maybe raise your burberry baseball cap up abit so you can see where second is you c*nt
who threw you a buttered biscuit you scrawny little c*nt!
Thats why he doesn't want to come to saffend tonight.............
people will realise his caps fake!!!
Originally Posted by Franco
True battle of the giants!!
I'll call it a truce & buy you a big mac meal....................Butter in my hands
tone, its ok.. ive got proper ones now!
pm received btw skip
Bet its the Alcon clutch. I had a six paddle on my fiesta and it fucked up . Was shagged from the start as it was noisey but i didnt know it was the clutch as i thought its new so couldnt be . It started to get crunchy one day then all of a sudden i was stuck at the lights on the fucking a406 at rush hour
XFactor replaced it though so credit to him cause i dunno whther he has been able to get the money back from Alcon yet.
Cars off the road at the mo with suspected clutch problem again so i will be getting something different next time as i had the flywheel refaced and it was fitted correctly just like the first time and its fucked. I dont no for sure its the clutch yet though cause i cant be fucked to sort it at the mo but im pretty sure its going to be.
Heres a pic of it
Heres a pic of it
Wes, the car has ford spec oil in the diffs and transfer, but some quiafe reccomended oil in the box.. i shall find out but i dont think thats the prob
www.ctuceilings.co.uk
I cracked up when I heard
No probs, you get Darrens number ok too?
The crunching will be because the oil is too slippery, the syncros can't slow down fast enough, syncros go CRUNCH!
Goto Ford and buy 2 litres of their MT75 oil, job done, if you haven't mullered the syncros already.
aah really wes? thats a bit shoiddy then as Oilman told me to use that oil to spec
did you get the probs im experiencing then?
to be fair.. ive avoided fast changes etc.. so its only happened anout 3 or 4 times (crunching that is)
hope you get it fixed
I use the same oil in gearboxes and diffs................
Silly question time - clutch cable? Not touching the heatshield or melted through in any way is it? I had similar clutch clearing issues albeit 2wd when the cable was mullered.
Should have hydrailced the clutch when it was out anyway
I had an R+D bigtooth gearkit, after getting the gearbox rebuilt twice by R+D using the oil they recommended (Syn5, and everytime the syncros were changed because they were kaput), i went to another gearbox builder (around the corner from Quaife), his exact words were "don't use that shite in an MT75, use the Ford MT75 oil", which i did, hey presto no more crunching
cheers Wes, ill drop the oil out and put some new in...
anyone want some silkolene syn 5? only done 145 miles! roflol!!!
Pon, i will check the cable.. pretty sure its ok though
Originally Posted by Porkie
You haven't got a Hydraulic clutch conversion???
I'm surprised, your attention to detail and prep on the car is normally superb....
whats a hydraulic clutch conv?
do i need one???
they arent easy are they!
luckily my engine was out when i fitted mine! still a pain though!
out of interest, how can you remove/fit so quickly? amy set methods?
