WILL MY COSSIE PASS ITS MOT?
Cars built or used after Aug 1992 had cat's fitted by law. If the car can achieve a pass without a cat, then it's not a requirement to have it fitted, but obviously the MOT for cat' year cars is more stringent.
K plate is a bit iffy, it goes on the build date not the registration date... so if it was built before aug 92 you're ok.
mine's a K plate and it dont need one
My september 1992 escos without cat passed the cat test only last week - Just.
Although I did play with the map a bit before hand.
I was told ALL cars sold with a CAT as original fitted after AUGUST 1992
has to have a WORKING cat to pass an MOT test.
Eg. I had a Mk V 130psi XR3i which was registered 30.09.92 and had a Mongoose exh on it. The build date of it was February '92 so I didn't legally need a cat.
