LOwering CR
Can the compression ratio (CR) of a YB,be lowered by changing the 4x4 head with a 2wd one? I found a add for pistons,sayng that if they are used with a 4x4 head shuold have 7.5:1 CR,and if used with a 2wd head should have 6.9:1 CR!!! Is this true??
That surprises me that it is quoted as that much, as when you fit standard 4x4 pistons with standard 2wd head, the compression drops from 8:1 to 7.8:1, so I am puzzled as to how it could drop so much just because the compression has already been lowered?
the effect (i.e. compression ratio change) will be much larger when used with a 4wd head (smaller combustion chamber) than 2wd head. mathematics. as the piston bowl volume will be more influential in the equation than with a more significant (head) combustion chamber volume...
well ihave just been sitting here with my sad calculator and seems mike is right again much as i hate to admit
according to my calculations, the lower the c.r. of the pistons, the less difference between using a 2wd and 4wd head
i reckon cosworth have it wrong (well it was only the salemen not the engineers) any EXPERTS??
SMILER258
Sep 28, 2015 09:04 AM
