AFR gauge and lambda sensor
Old Oct 18, 2005 | 01:18 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
Default AFR gauge and lambda sensor
ive recently installed an autometer AFR gauge and am currently using the standard ford zetec lambda sensor, the gauge is constantly reading rich.
ive looked thru the instructions for the gauge and seen the range of voltage the gauge wants to see is 0-1v im seeing around 3.3v at idle across the sensor dropping to around 2.8v when revved.
am i usng the wrong lambda gauge or have i wired it wrong?
if im using the wrong sensor can someone point me in the direction of the correct one
ta
Old Oct 18, 2005 | 02:08 PM
sjoyce666's Avatar
sjoyce666
not sure if you have the correct gauge but i have one that i bought off of gadget to use with my gauge but i've since sold the gauge but still have the sensor
let me know if your interested
Scott
Old Oct 18, 2005 | 02:21 PM
foreigneRS's Avatar
foreigneRS
Testing the future
of course the gauge is reading rich if that's the voltage that it's seeing.
don't see how you get that voltage out of a narrow band sensor though
how many wires does the sensor have, and what colours are you using?
Old Oct 18, 2005 | 04:23 PM
Chrissy_bwoy
sjoyce666
cheers mate, may give you a shout
im using four wires, cant remember colours etc as its standard ford fitment, taking a feed off the supply to the ecu +/- 12v for heater and 5v for feed as per ford wiring
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
