Gauges.....
Old Oct 17, 2005 | 08:54 PM
BillyCabrio's Avatar
BillyCabrio
Default Gauges.....
Apart from the obveious boost gauge, what would you say is the next most important gauges to have?
I'm thinking...
1. Boost
2. Oil Pressure
3. Oil Temp
4. Water Temp
I already have an ACT guage
I'm also very limited with space, are there any gauges that double up? i.e. have 2 features instead of the usual one?
Old Oct 17, 2005 | 09:06 PM
Benn 304R's Avatar
Benn 304R
for 2 in 1 you have either racetech or spa afaik.
Racetech are cheaper.
Old Oct 17, 2005 | 09:13 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
SPA dual gauges are very good, but they are expensive...
I would say all you would need mate to be honest is Boost, but it depends if you really want some gauges, and how many. The more gauges you have the more you have to worry about.
Old Oct 17, 2005 | 09:18 PM
BillyCabrio
Nice one, cheers mate.
It was the SPA one's i was after
Old Oct 17, 2005 | 09:20 PM
BillyCabrio
Tony Turbo
2 4 1 is what i need as i'm very limited on space.
I just wanna keep an eye on the important stuff......
What do you think?
Old Oct 17, 2005 | 09:22 PM
Benn 304R's Avatar
Benn 304R
there around Ł250 each afaik.
3dr stretch has them in his cossie I think.
Considering them for Chelle's car.
Benn 304R's Avatar
Benn 304R
how about egt?
Old Oct 17, 2005 | 09:24 PM
Manchester Mike's Avatar
Manchester Mike
Oil pressure, water temp, fuel pressure, the time
Old Oct 17, 2005 | 09:27 PM
rsnissan's Avatar
rsnissan
spas duals are the way to go i have 6 gauges in effect but only takes up the space of 3
Old Oct 17, 2005 | 09:29 PM
rsnissan's Avatar
rsnissan
excuse the act's ect i was fiddling about with the peak recall and triggers
Old Oct 17, 2005 | 09:30 PM
Tony Turbo's Avatar
Tony Turbo
241 gauges?
I only planned on buying 4 Defi's originally, Boost, Oil Temp, Oil Pressure and EGT, but that was because I planned a powerful engine and planned to put it on track and give it some abuse. I think too many gauges for the road is overkill, especially on a standard ish car, but they are handy at times. I wouldn't bother with EGT's, as there is fuck all you can do with them anyway, and I never have a problem with them, the gauge is just handy for mapping.
Have a look at SPA's site, they do different combinations of gauge, but I would suggest Boost, Water Temperature, Oil Pressure and Oil Temperature, if only one gauge, then Boost and Water, imo, that's if SPA do that combo, which I am very sure they do.
Old Oct 17, 2005 | 09:32 PM
starturbo's Avatar
starturbo
definately oil press and temp.ive had 2 motors blow up coz of oil.
Old Oct 17, 2005 | 10:41 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Paul, you keeping the Factory Water Temp Gauge? If so, why have another one? Its not that important to know the exact temperature of your Coolant.
I would personally put the need for Gauges in this order........
1. Boost
2. Oil Pressure
3. EGT
4. Fuel Pressure
5. Oil Temperature
6. Water Temperature
That doesn't mean I would have all of them.
But, Tony has spoken some sense. The more Gauges you have, the more there is to watch, which can be a real pain and most of them are just academic, incase something goes wrong. Often I find that my Gauges behaving the same way every single time I take the car out almost become part of the scenery and I wonder if I would definately notice something going wrong in time to even have an effect on it.
Old Oct 18, 2005 | 12:25 AM
BillyCabrio
Not to bad me thinks for a 2 in 1 jobbie
http://www.spa-direct.co.uk/instruments/dualgauges.htm
Old Oct 18, 2005 | 05:35 PM
Sean_RS's Avatar
Sean_RS
Ive got boost, oil temp, oil pressure, water temp... thinking of adding volts
Old Oct 18, 2005 | 06:18 PM
JamesH's Avatar
JamesH
Boost and oil pressure IMO
bezo
Feb 9, 2012 04:58 PM
