where can i get a big wing baffled sump for my 2wd ?
as title when my oil is a bit low my defi has started to beep at me under heavy braking and cornering.
Not good
Not good
just finding my feet
craig from what ive heard dingy,,,,,,,,, yes DINGY and oli do a 2wd baffled sump, try him first then the usuall people
even pro alloy might fancy the challenge , i can measure up mine( as im resting my feet on it as i type, there soo usefull ) and that would give ya somink to word from
craig think its about 200 quidish
from what ya discribing i sugest you cheack ya oil levels first
also whats ya normal oil peasure as you got a oil cooler too aint ya ??
lol
im not that daft oil level is ok
yes i got oil cooler. my oil pressure is usually arround 3bar mark when warm and just under 4bar when cold
craig speak to karl as i was told that a oil cooler was not needed ona road car and the fact ive got a big wing sump too would keep the oil too cold ect
have a chat with god and see what he thinks
craig i cant see the sump helping under braking though ????
as in most people fit em as a precaution but not when they find a problem
but then im not experienced enough to answer with a reply of worth
but ive been in a few cossies doing donuts and the oil light aint came on yet
hope you understand what im saying
marco thats a totally different design, mines the same as pons. yours is lower and does under the cross member im guessing
my holds 7 litres in total,,,,,,,,,,,,,,, what does yours hold with the engine
the std oil pressure sensor is wank lol
i have a defi with a set low limit
i have set it to 1.5 bar
it is not the sump that stops the surging ginge but the gating in it as marco's pics show
ppl with track cars fit these and as i track my car and i dont have one i am seeing the symptoms of not having one.
that is why i want one
Look carfully this is a gated system sump and totally diffent to Pon's
the only thing is the same as Pons is the return to sump
it works in every direction braking ,accel,cornering left ,conrering right ,
the gates work according which means it keeps "the same amount of oil" in the sump at any postion ,any time
it sits below the Xmeber but sits level with the bottom of the xmeber
it's proper trick and it's the same design as the touring car Rs500's
it's holds 7.5/6litres in total
if you look carfully you will see than on the left hand side is a funny shape and thats because of the starter motor sits there
Pons sump no offence ,but they are better than not having one ,the only down fall with them as they are too slow letitng in the oil because they have holes drilled inside the sump where the wings are so the sump has no controll over the oil speed coming back into the center of the sump
Marco
hey marco thats what i noticed about ya sump , mines the same as pons ( i got mine first though,,,,,,,, and it came with the car )
and must admit ive wondered about the use of it breaking, hence my reply to craig
also noticed that its lower, a better idea than just adding wings too , never new there was holes drilled int he wings in mine, i was thinking about why not cut a letter box out the bottom of my sump then add the wings, guess i know know they done something
oh nad my sump MUST take less than yours
is a work of art,,,,,,,,,,,, cue for the pro allouy boys to offer this on there range too ( i want a finders fee for the idea though )
craig what ever ya decide may i sugest doing a few outlest ( oil temp, return and drain plug) just for the pro look
Griag
The oil pick up pipe is alterd and re-postioned
this is what i don't want to do is get the guy to make them and you lot don't have them
if any of you are seriouly intrested then i will need a 2wd sump in part ex
i will also need you tell me which oil pump you are using i can tell him
as for cost i will speak with him the weekend
as the for the guy who makes them is a down to earth genuine guy and not so much in it for the money
but you will have to pay Lenny's tax on them it won't be much thats just to cover petrol /and phone bill
Marco
Marco
