Reyland Escort - Version 2 Build Pics
#41
Originally Posted by Stealth Bomber
So what is a millington ****** cover anyway? What makes it different and why?
Prokie (despite not knowing what a rocker is) will probably know far more about it than me though, thats the funny thing about him, he knows all about the weird and wonderful stuff and not about the really basic stuff, quite an unusual guy in that respect, despite being of no use to anyone mechanically he is a fountain of knowledge on things that most of us know little about!
#42
Chip is spot on about the engine. Martin used to use a Millington Diamond block. Lighter and taller.
I presume a Rocker is like a cam follower?
I am of LESS than no use mechanically as well... I break things VERY easily and this causes more problems. So now I don't even try
#43
Basically on a 8v engine (well more ot the point a single cam engine) or a pushrod engine you have them normally.
So where the cam sits in the middle on an 8v it pushed up these little seesaws that site facing either side of it, 4 to the exhuast and 4 to the inlet, as they push up the other side pushes down and opens the valve.
Same sort of thing with pushrod engines (where the cam sits in the blocks) they push a rod upwards and then a little seesaw converts that into a downwards movement instead of push the valve open.
#44
Give us engine specs martin... PLEAAAAAASE....
#48
But Millington is a very trick engineering company the basically rework the YB engine and make it even better, I think they tend to take them out to 2.4? and also most the Millington engines I have seen have been N/A but again i'm probably wrong.
#50
GtechR, we have already answered this mate. They make the YB block out of lighter ally and they are also taller blocks. This allows bigger capacity without having to compromise on internal geometry I think. You are correct about most being N/A though...
Anyone seen the Colin Mccrash's new Mk2 built by DJM? Thats got a Millington engine
#51
#54
Originally Posted by PF Ben
Chip - if you're stroking a YB you REALLY shouldn't shorten the rods.
Ben
Ben
I already know that, or i wouldnt have posted not having to do so as an advantage of the millington block in this thread a few hours ago.
If you are stroking a YB engine though, you dont really have a lot of choice but to shorten the rods sadly!
You can move the gudgeon pin up a little, you can raise the pistons slightly further in terms of deckheight, but then thats it, after that if you want to stroke still further you have no choice but to go for shorter rods if you want to increase the stroke further.
You only have a finite amount of space between the top of the block and the bearing tunnel, so without increasing that via a new block, you HAVE to shorten the rods to stroke it very far.
#57
BTW did i mention my suspension was 10k new?
bosch-man look at the autronic post.
martin looks ace.
#66
Re: Reyland Escort - Version 2 Build Pics
Originally Posted by Ish
A lot of people don't really look at any other parts of P.F apart from 'General Discussion' but have a look at the ' Restorations, Rebuilds & Projects.' section at this post https://passionford.com/forum/viewtopic.php?t=91171
Should be a lot of regular updates on that post from now on as Martin is making proper progress with it now
#71
Originally Posted by dingy
Martin have you had the back arch's done the same as scotties wrc car to make it look wide as fook ?
#73
Originally Posted by Lee Reynolds
did you paint it Martin?
#75
Looking good...
muz
16-08-2015 12:57 PM
