HELP, Heater problems on my Mondeo
i have a problem with the heaters, in that they only work on setting no 4
settings 1,2 and 3 dont turn the fans on.
any ideas?????
any ideas?????
woooo!! if you dont mind, that would be cool!!
ta, tosser
We've rearranged karting dude, tis sat 8th now, just so you know
no stress if you're too chicken though
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Originally Posted by rsnissan
resistor in switch is fooked............................................ new switch time
that it?? 5 min job???
ta, tosser
plus as i just bought a roof and roller door cost Ł1100 i'm kinda skint
pm me ya address to send it over dude
theres a resistor in the heater box in the pass footwell, they normally melt the wiring too, about Ł25 from ford from memory, 5 min job
Testing the future
resistor cannot be in the switch - i would like to see a resistor that fits in there that is capable of passing over 15A
don't know where they are on a mondeo, but rob @ scc seems to. they're usuall somewhere that gets a bit of airflow though, cos they do expel quite a lot of heat.
Well my switch had a whole unit at the back of it. As said this was on a pulsar though so may well be different on a mondy.
maybe the switch itself was fooked on mine and not the resistor then?
Testing the future
not saying your wrong Andy, it's probably just that nissan control the fan speed in a different way rather than just dropping the voltage across a whacking great resistor
Originally Posted by Rob@SCC Performance
theres a resistor in the heater box in the pass footwell, they normally melt the wiring too, about Ł25 from ford from memory, 5 min job ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
100% correct
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
just finding my feet
fords do a kit its about Ł15 for the resistor and new cable with multi plug..........tis a known fault
thats true,spiky do ya have the mk3 shape mondeo with the screw hole in or the earlier one with the springs on show
its a actualluy design fault, sold one today actually, you need to solder the wires and not scotch lock em
the resistor is 1311115 i belive ( or close to that , sell about 4 a week
the wire is about 7 quid odd and the resistor is 8 quid odd
spikey when ya take the resistor out theres 2 styles, the older style clips is and the newer style has a screw hole in it, ( thats the 1311115 with screw)
as its a N reg it could be either
take ya reg down and they will tell ya at fords
unless ya tell me how i can bypass the password at work and i can do it for ya tommorow
